Home > Technical > Suspension problem
Jonesyscoob
Suspension problem
The red light with arrows round it came on and a 30mph warning, car got very bumpy, pulled over turned off and car seems to have lowered itself, started car again no fault appeared so sailed the suspension to normal height, couple of journeys later same again, any ideas
Post #384994 Sat Jun 08 2013 2:59pm
fallschirmjager
United Arab Emirates 2008 Range Rover Sport Supercharged HSE Luxury Alaska White
Happened to mine a few weeks ago. There was a leak in the air suspension. Got new front suspension fitted under warranty, though apparently the service rep said I should have paid for it as suspension is only covered up to 60000 miles. Had it done FOC though.
Post #384996 Sat Jun 08 2013 4:41pm
PEACHY
Is the compressor really noisy - it's on the passenger side in front of rear wheel. What year is the RRS & how many miles has the car done ? 16MY Estoril Blue SVR.............
Post #384997 Sat Jun 08 2013 6:53pm
Jonesyscoob
2006 sport done 91000, compressor sounds normal, didn't know where it was til I got down to see where the noise was coming from, any other ideas?
Post #384998 Sat Jun 08 2013 7:18pm
PEACHY
Pm sent. Thumbs Up 16MY Estoril Blue SVR.............
Post #384999 Sat Jun 08 2013 8:03pm
Jonesyscoob
Had the codes read today this is what I got, they all cleared but for some reason the air bag light has come on and won't clear just comes straight back on, problem happened again on the way home so codes will be back!
Post #385133 Mon Jun 10 2013 8:50pm
Gary
I had this last night on my way home, light came on, front end lower than rear and could hear compressor, very bumpy ride?
Post #385352 Thu Jun 13 2013 6:59am
outback4x4uk
I had a problem a while back now where the same dash lights came on that you had, and the ride also dropped to bump stops, it turned out to be a ride hight sensor in my case.
Worth checking, what I did was to bring up the 4x4 info screen on the sat nav, and check the wheel hights against the displayed red level lines mine was showing one not lined up, checked and found a damaged plug, repaired it, and has been fine ever since.
Just my 10 cents worth if it it helps out Thumbs Up . 08 RRS TDV8 stornoway grey.
06 RRS TDV6 hse Rimni red-----gone!
05 D3 TDV6 se Alveston Red----gone and missed!
53 D2 TD5 xs Epsom Green-----gone!
99 D2 TD5 xs Epsom Green-----gone!
96 D90 300tdi rioja Red---------gone and missed!
Many more come and gone.
Post #385354 Thu Jun 13 2013 9:09am
Gary
Just had a diagnostic check and the compressor is on its way out, apparently i am lucky its lasted 7 years Crying or Very sad
Post #385357 Thu Jun 13 2013 11:09am
PEACHY
Post #385360 Thu Jun 13 2013 12:43pm
