Home > Maintenance & Modifications > Problem with spare wheel winch.
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
I have had to use the spare a couple of times in the past few weeks and now can't get the winch to go all the way up to secure the spare wheel in tightly. Is the cable caught up inside the mechanism and if so is there any way to free it off or will I have to have a new winch? For the time being I have put the wheel back under the other way round with the outside of the wheel facing the ground so the cable is tight, is this ok to do?
Post #381692 Sun Apr 28 2013 10:19pm
mse
There are a couple of posts on here, one recently about how to repair the winch, might be worth a search. If your winch is tight you might be ok but I would want to be sure it's locked properly.
Keep an eye on it and get it fixed...could you not take the spare off for the mean time? Mike
2014 Facelift Discovery
Post #381694 Sun Apr 28 2013 10:56pm
1JBS
Thanks mse, any solution or thoughts anyone else ?
Post #381876 Tue Apr 30 2013 11:30pm
Paddi
JB,
I think you might find this thread more helpful: http://www.rrsport.co.uk/forum/topic30676.html?highlight=winch
If the cable is wound back on to the winch drum whilst there is no tension in the cable then it is likely to jam owing to overlapping turns. Those of us who sail keelboats are very familiar with this phenomenon and call it a 'riding turn'. I've not had the problem on my spare wheel winch but understand the first thing to try is remove the winch from the car (it's only four bolts) - secure it in a vice on a bench and then get someone to pull as hard as they can on the cable whilst you turn the winch operating bolt anticlockwise. If this doesn't work then try the dismantling procedure in the link.
To avoid future similar problems - never wind the winch up without any tension in the cable. 2008 MY Java Black TDV8 HSE
Post #381901 Wed May 01 2013 10:28am
1JBS
Many thanks Paddi, that's exactly the answer I was looking for.. Thumbs Up
Post #381938 Wed May 01 2013 3:39pm
mse
Wasnt that what i said basically Rolling Eyes Embarassed Mike
Post #381946 Wed May 01 2013 4:45pm
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Paddi wrote:
JB,
I had this problem, bought a secondhand one from Landrover Breaker.It did not work properly,sent it back and bought a new one.I took the old one apart to see how it worked and found the problem,. I had unwound the cable too far to get the wheel from under the car. And it had come to the end of the cable ,and started to wind the other way .It kinked the cable at the anchor end and jammed the whole thing up. I tried to straighten the cable but it would not go into the groove again.Solution Dont wind up without tension on cable, and dont unwind to far when taking spare off Big Cry itisme
Post #383306 Fri May 17 2013 9:43am
^^^ Seems a particularly shoddy way to do things for a 50-80k car IMHO.
Does the new MY14 have a similar set up I wonder Question ON THE WAY: BMW F21 M140i
Post #383311 Fri May 17 2013 9:59am
whippetman
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Don't know but it has a £2k+ towbar Whistle
Post #383318 Fri May 17 2013 10:24am
muddywheels
Milk Float Man
Lots of posts on Disco Sad
http://www.disco3.co.uk/forum/topic17984.h...e+%2Bwinch
http://www.disco3.co.uk/forum/topic80879.h...2Bwarranty
http://www.disco3.co.uk/forum/topic94631.h...e+%2Bwinch
http://www.disco3.co.uk/forum/topic85860.h...e+%2Bwinch Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #383322 Fri May 17 2013 10:40am
mse
No the spare is inside and has a internal winch type strap thing to get it out of the boot.
Oh unless you go for seven seats then you dont get a spare. Mike
Post #383368 Fri May 17 2013 3:33pm
Cheers Mike Thumbs Up ON THE WAY: BMW F21 M140i
Post #383373 Fri May 17 2013 3:37pm
mse
Here to help (or hinder Whistle Rolling with laughter ) Mike
Post #383379 Fri May 17 2013 3:56pm
cristalfb
Australia 2011 Range Rover Sport 3.0 TDV6 SE Ipanema Sand
Disco 3/4 RR Sport wheel winch repair.
I know its been done to death, but I have repaired my wheel winch and have the procedure with photos in PDF format. If anyones wants a copy let me know and I will email it to you. I cannot attach it here unfortunately. The cable was kinked badly and the shaft was spinning in the housing. It works fine now. I have posted this on the DISCOUK site as well.
Good luck from OZ. Thumbs Up
Post #388574 Fri Jul 12 2013 3:06am
BioBMS
England 2009 Range Rover Sport TDV6 HSE Santorini Black
Pm for you cristalfb
Post #388575 Fri Jul 12 2013 6:20am
