![]() | Home > Technical > The correct ride height for the RRS |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 441 ![]() ![]() ![]() |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9144 ![]() ![]() ![]() |
The system is only accurate to about 10mm when running in normal tolerance so +/-12mm seems reasonable (assuming they mean "within 12mm" rather than "within 24mm" (which is what +/-12mm actually means)) 2012 SDV6 - it's missing a couple of cylinders
Hello
quantumjohn Member Since: 17 Mar 2013 Location: NW Kent Posts: 53 ![]() ![]() |
That seems like a large tolerance still. If it was down one side and up the other by 12mm each that would be visibly noticeable.
12mm is nothing I would suggest Mike
