Home > Maintenance & Modifications > windscreen wipers |
TrevG Member Since: 14 Aug 2012 Location: Kent Posts: 48 |
I got these no issues so far
Sun Mar 17 2013 5:33pm |
defender_uk Member Since: 08 Aug 2006 Location: North Yorkshire, Pickering Posts: 169 |
same boat as u Ilard.... |
Sun Mar 17 2013 6:20pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8873 |
I have found the LR supplied wipers to be as good as any others and better than some. 2012 SDV6 - it's missing a couple of cylinders
Sun Mar 17 2013 6:49pm |
Try giving the windscreen a really thorough clean with Autoglym fast glass and then apply Rain X rain repellant. If the wipers still squeak or judder try twisting the flat metal part of the wiper arms a little to change the angle of attack by a small amount. This might require a bit of trial and error until it is just right. 2008 MY Java Black TDV8 HSE
Sun Mar 17 2013 7:06pm |
ilard Member Since: 20 Aug 2010 Location: London Posts: 972 |
Good advice, Paddi, my screen probably needs some TLC to help get the most out of the wipers. I think the guy who cleans my car is more of a splish splash splosh sort of a fella. But my ineptitude at tweaking / fettling / DYI is infamous in my household so I better leave that to someone else.
Sun Mar 17 2013 7:52pm |
Fair enough. Note you are in London so traffic film on the windscreen will be worse than a rural car. Those aerodynamic after market wipers do look quite cool tho' Let us know what you think of them? 2008 MY Java Black TDV8 HSE
Mon Mar 18 2013 6:23pm |
zee Heyner Hybrid wiper blades have worked out well and certainly have a nice swipe about them. Only issue is that they look abit ugly from the driver's seat because the clip structure is exposed - i.e. no spolier cover. I wonder if I was supposed to remove a part of the old wiper blades.... (I still have them so I can take a look) L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Wed Mar 27 2013 5:20pm |
Java SC Member Since: 23 Mar 2013 Location: North Wales Posts: 21 |
Just ordered the above for the front and the below for the rear... http://www.ebay.co.uk/itm/Complete-rear-wi...7431195%26 I will let you know how I get on..... Java RRS Supercharged + Jaguar STR Supercharged, = Oil Refinery.... |
Wed Mar 27 2013 10:48pm |
