![]() | Home > General > EXHAUST tips 05-09 diesel straight through |
HICKY555 Member Since: 27 Jan 2013 Location: WORCESTER Posts: 208 ![]() ![]() ![]() |
[url] http://www.adamesh4x4.co.uk/range-rover-sp...-488-p.asp [/url]
I have ordered a pair will post photo's |
Just so you know Hicky,
they are bolt on so I can remove if required for MOT |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4506 ![]() ![]() ![]() |
Had a Fabia vRS, which had an outwards facing exhaust from the factory, never had an issue with MOT's etc... |
All VAG group cars run partial filters so that's allowed. Most modern TDI have straight tips. 2x TDV6. SE and HSE. Both returned to sender with issues👀
RRSNorway Member Since: 08 Jan 2012 Location: norway Posts: 314 ![]() ![]() ![]() |
Can't wait for the result ![]() Damn the large shipping cost to Norway! RRS 2006 2.7 HSE |
Mine didn't. It had a CAT, but not a DPF, which is the same as the 2.7 RRS... |
Strange..... Usually a filter after the turbo at bulkhead. Can't see why Skoda would use Pumper Diesel engine (PD) and not use standard downpipes.
It will be nice to get some feedback on just how much muck finds it's way onto the back of the car, I have thought about fitting a couple of chrome or better still black trims (I am not into this cleaning / detailing stuff) however have been put of by the thought of a tailgate covered in diesel smutt, plus paying Circa £50 or £60 for a bit of 2inch pipe |
Even after long journeys towing or not, there is little difference to what goes up bumper and tailgate on mine. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Stryke Member Since: 16 Nov 2010 Location: UK Posts: 99 ![]() ![]() ![]() |
To be honest I'm not a fan, would prefer the oval shaped Hawke tips which look better. |
