Home > Faults & Fixes > Help Compressor Replacement
Tim Hoang
Hi Everyone,
I tried to romove the air suspension compressor and could not take the Inlet and Exhaust Pipes out so I cut them but still could not remove those stick to compressor. are those fittings availale separately? Or is there any other way to get round it?
Help!!!
Big Cry Big Cry Big Cry 2005 RRS TDV6 HSE Java Black
2005 997 C2
Post #373759 Sun Feb 17 2013 4:52pm
flack
You can get the pipe and the joint connectors from memory I think they are 6mm and 8mm, I have done loads this way.
The big 8 mm pipe has a brass ferule on the inside but the new pipe is that good and stiff you need to to use it just shove the pipe in fully home.
You can but short lengths from Ebay then just just get some push on quick release straights or 90" bends job done.
Flack
Post #374704 Mon Feb 25 2013 4:19pm
Mitchmx
I changed mine last week. Just cut the pipes and bought a few connectors off eBay. It is 6mm 8mm and 10mm you need. Thumbs Up
Post #374784 Mon Feb 25 2013 10:50pm
