Home > Faults & Fixes > HELP: Transmission fault messages? |
As daft as it sounds, check your brake light bulbs. |
Tue Jan 08 2013 4:32pm |
Mike_C Member Since: 19 Mar 2012 Location: Bucks Posts: 184 |
Really??? Is that a known cause for those particular error messages, or for all sorts of random error messages? - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE) - BMW 330Ci M-Sport coupe - Suzuki GSX-R750 K6 'Stealth' - trackdays and high speed tourer |
Tue Jan 08 2013 4:49pm |
Yes it has been known many times before. |
Tue Jan 08 2013 6:34pm |
Thanks Ady, will check!
Tue Jan 08 2013 6:57pm |
ELD70 Member Since: 20 Jan 2009 Location: UK Posts: 163 |
Do they clear after a while.....battery may need a good charge. |
Tue Jan 08 2013 7:23pm |
So i'm lead to believe, also check your battery & alternator are in good working order. |
Tue Jan 08 2013 8:49pm |
Bob. Member Since: 03 Feb 2009 Location: SWest Posts: 275 |
Maybe they disturbed or damaged the wiring to the range change motor or the transfer box. Have you had a look?
Tue Jan 08 2013 11:29pm |
Apparently it needs a new gearbox ECU - great!! - Range Rover Sport 4.4 V8 HSE G4 Challenge vehicle (FOR SALE)
Thu Jan 10 2013 2:05pm |
gruodiz Member Since: 27 Nov 2011 Location: Klaipeda Posts: 63 |
Mike_C how did you solve the problem?
Wed Jan 23 2013 6:49pm |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 |
Is it possible to have the ECU reflashed by someone with a faultmate? Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section
Wed Jan 23 2013 7:07pm |
I have JLR SDD and already reflashed the module but with no success, just took stop light switch off and see that its burnt a little bit inside, will see what to do.
Wed Jan 23 2013 7:17pm |
Ah yes - the stop light switch is another common problem. Hopefully a new one will fix your issue Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section
Wed Jan 23 2013 7:39pm |
imb111 Member Since: 30 Nov 2012 Location: UK Posts: 28 |
The specialist wouldn't be the one where the old mini garage was in maidenhead would it?
Wed Jan 23 2013 8:50pm |
Finally looks like solved the problem. Firstly changed all back light bulbs to new and good quality, then cleaned the brake pedal switch but these two did no change even after transfer box module reflash, then gearbox module reflash and engine ecu reflash because I had engine light sometimes. The last was transfer box solenoid connection chech and voila It looked very nice from outside even from the inside, but reconnection helped.
Thu Jan 24 2013 10:24pm |
