Home > Wheels & Tyres > Spare Tyre Wire - not winding properly
Franko
Scotland 2006 Range Rover Sport Supercharged Fuji White
Hi guys
To add my annoyance of hitting a pothole and bursting my tyre and damaging my alloy. When the garage was trying to unwind the wire to put the spare tyre back on, its seized.
Its now just spinning. Hanging down. It wont wind up or down and the garage says i need to take it to a Land rover dealer.
Does anyone have any idea how much this is goin to cost me (on top of my new tyre, its killing me lol) or does anyone know how to fix this.
Thanks Range Rover Sport Supercharged 2006 plate
Post #365014 Fri Nov 30 2012 7:29pm
mse
Well if you look on here you will see the price for the replacement stuff following thefts £200 ISTR
The winch failing like that might be down to your (or tyre person) use...there are some issues with winding it up without the wheel damaging it - over winding etc etc.
I assume your car has no warranty? Mike
2014 Facelift Discovery
Post #365020 Fri Nov 30 2012 8:02pm
Franko
No its out of warranty unfortunately. It was winding down a little but now it is just spinning Sad Range Rover Sport Supercharged 2006 plate
Post #365021 Fri Nov 30 2012 8:11pm
mse
Think you will find its a new one then. I would take it off and see if it can be repaired, but thats how my brain works
Simple replacement task 6 bolts (from memory) and you will get the new design replacement.
No wheel to worry about Mike
Post #365022 Fri Nov 30 2012 8:16pm
Franko
i'll give it a shot. Try n take it off myself and see how it goes.
6bolts u say? are they visible from underneath the car. To be honest ive not even looked as it was dark when i picked the car up. Range Rover Sport Supercharged 2006 plate
Post #365024 Fri Nov 30 2012 8:35pm
mse
Yep 6(might be Cool bolts visible with the tyre off...should be one of the more straight forward jobs. Mike
Post #365050 Sat Dec 01 2012 9:53am
Bradders
Well known problem. It's a new winch assembly in my experience. FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
EX 2007 FL2 XS - not so bad
Post #365053 Sat Dec 01 2012 10:37am
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Total waste of time trying to repair, its a sealed unit, i prised it open but to no avil.
£80 from LR if memory serves me correctly and half hour max to fit.
Post #365063 Sat Dec 01 2012 11:49am
PEACHY
Had this problem myself - nearly gave up but a Rac friend came to my rescue - remove the sealed unit from the car - place it in a vice - slowly but with force pull the cable out of unit - get someone else to hold a ratchet / spanner on the bolt that lowers - highers the cable on the unit itself - this is to add resistance. I've now had to do this process twice both times with success. It's a known fault but doesn't have to mean replacing.Good luck. Thumbs Up 16MY Estoril Blue SVR.............
Post #365116 Sat Dec 01 2012 10:27pm
