Home > Faults & Fixes > Problem with window sprinklers
Fatandre
Iceland 2006 Range Rover Sport Supercharged Santorini Black
The winter is here and the salt is everywhere. I have a problem because my window sprinklers dont seem to work.
The headlight one works, but not the front window.
Is there any fuse that I can check? Where would it be located?
Has anyone had this problem?
Its a 2006 RRS. 91 BMW 850CSI
Post #364053 Thu Nov 22 2012 1:51pm
mark hamster
i had this happen a few months ago..! all worked fine and then one by one they stopped working.M O T was due so i read on here to get a thin wire or cut a bristle off a yard brush and push them in and out off washer jets and hey presto mine all started working again,hope you have same luck as me Thumbs Up
Post #364055 Thu Nov 22 2012 2:06pm
