Faultmate Updates - Southern Ireland
I'm planning on coming over to sunny(?) Southern Ireland before Christmas to do some Faultmate updates.
Will be based around Cork/Waterford area, but may be able to arrange others.
I'm not sure on exact dates yet, but please let me know f you are interested in any of the updates for Disco3, Disco4 and RRS.
I'm planning on trying to centralise the udpdates as much as possible throughout the day, evenings may be available also.
If you are interested, please let me know, PM or email
I can take payment in Euro's no problem.
The main updates available as below.
This should be familiar to you, its the Standard Dashboard
Clock On The Dashboard/Lights On indicator
After Clock On The Dash is ENABLED - LOOK a Clock you can see! (Why LR didnt do this in the first place I have no idea.....)
This is shown with the Lights switched OFF
This is shown with the lights switched ON so you can now tell if your lights are on or off.
And a close up. As you can see, the "Lights On" indicator is in fact the old (No longer used) Fuel Burning Heater indicator and is pale Red.
Three Flash Indicators
Three Flash Indicators can't really be shown (other than in a vid perhaps) but it is when you tap the indicator and the indicators then flash three times and self cancel. Makes it easy work on motorways etc for changing lanes without you having to remember to switch it off
Gearbox Reset/Recalibration
This resets your adaptive gearbox back to factory values (it remembers how you drive) it will also recalibrate the Transfer box, combined together, it often results in a smoother drive and has been known to help resolve symptoms of some gearbox juddering. This is not always guaranteed as there can be many causes of this symptom, but this is certainly one of the cheaper options to try first.
Sat Nav On The Move
This is a long update (90 minutes) but is very very popular as it is incredibly frustrating to have to keep stopping to change your destination. This update allows you or your passenger to make any changes to your satnav destination whilst driving. Instead of seeing the greyed out screen, you will see this....
To prove it works when driving...
Thanks to Chris for letting me take the Pictures of his updates
PhoneBook over Blutooth Update
This updates your standard factory Fit RRS Blutooth module to enable you to select your phonebook contacts from the screen of your radio display. It also fixes issues with iphone etc where you have to enter the 2121 code in each time you want to connect. I can do this one by post also and its very easy to change on a RRS.
service reminder reset
This resets your service message. some independants are not able to reset your servcie indicator after they have changed oil etc. this can be reset for another year.
Read/Reset Fault Codes
Can also Read and reset All fault Codes and provide you with an e-mailed list of any that come up if needed. This could save you a more expensive trip to a dealers.
Another popular one is to purge and test the Fuel Burning Heater so that it makes sure it works ready for the winter and update other modules as needed.
If you would like any of these updates, then please feel free to PM or e-mail me. It helps if you include your postcode and model year and what updates you would like to have done.
IanBodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE
Mon Nov 05 2012 11:42am
Bodsy Site Sponsor
would this have any more interest if I went via Dublin?Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE
Mon Nov 12 2012 11:36am
RRSIreland
Hi,
I am in Dublin and interested. I have a 2005 RRS 2.7SE with 190,000km, no sat nav or bluetooth.
What price are you charging?Eoghan Kavanagh
Dublin
Ireland
