Home > Technical > Washer jet problem |
Sorted same problem by pulling out a single bristle from a yard broom and poking it down the washer jets as far as possible. Not as risky as using a needle (as the LR manual helpfully suggests) since the bristle can't damage anything - just make sure you keep hold of the end.
Wed Aug 22 2012 2:58pm |
Skipper Member Since: 13 Jan 2011 Location: Essex Posts: 25 |
Similar advice here, but I used a piece of wire from a wire brush. Worked a treat |
Wed Aug 22 2012 3:07pm |
