Home > Wheels & Tyres > Brembo Brakes and 19inch wheels
drdelrrs
I was considering whether my 19inch winter wheels that I used on my TDV6 would fit my 09MY TDV8; it's currently running on 20inch rims.
The Brembo calipers have two rectangular weights ( about 50mm x 25mm x 25mmeach attached by an Allen bolt to the back of the caliper at the top and bottom) that are presumably harmonic damper weights. With the 19inch wheels fitted - these weight reduce the clearance to about 5-7mm which seems a bit close so I was thinking I'd remove them.
Anbody seen these 'weights' and know whether removal would be a good or bad idea?
Post #352133 Sat Jul 28 2012 7:08pm
C10KO
Mate 19" fit with no issue - no need to remove anything, I'm running the same combo Thumbs Up
Post #352136 Sat Jul 28 2012 7:44pm
flydive
As C10KO said, you should not need to remove the weight, wheels will fit ok.
If you feel they are too close for comfort, just turn them around 180°. I did that to fit the 18" with no adverse effect. '08 RRS TDV8
Post #352143 Sat Jul 28 2012 9:12pm
vnitos
South Africa
@flydive, which 18" wheels are / did you use?
Post #405358 Sun Dec 08 2013 8:36pm
flydive
Compomotive PD1880
http://www.comp.co.uk/news/index.asp?page=...-period-35 '08 RRS TDV8
Post #405369 Sun Dec 08 2013 10:12pm
Stephen J
Netherlands 2005 Range Rover Sport Supercharged Java Black
I just read that Compomotive went out of beeswax. Any info on that?
Post #405801 Wed Dec 11 2013 11:24pm
flydive
They are still trading. PD1880 still available.
A user on the Disco site just got them
http://www.disco3.co.uk/forum/topic104104....ompomotive
Here a info on their site
http://www.comp.co.uk/info/index.asp?page=...cturing-53 '08 RRS TDV8
Post #405816 Wed Dec 11 2013 11:59pm
Stephen J
Thanks for that!
Post #405850 Thu Dec 12 2013 10:30am
