Home > Technical > Electronic trouble with my RRS
RRS67
Italy 2006 Range Rover Sport TDV6 HSE Tonga Green
Hallo to everybody!
I want to notice to you a problem I had on my RRS and for which the car has been stopped for 3 weeks by the car dealer.
It started a morning when after opening the car and not turning the car on but only inserting the key in the panel some check warnings appeared on the display :
- gearbox. engine, HDC, suspension, brake, etc, etc.
The car has been towed to the car dealer where the ECU has been replaced.
After 2 weeks I picked the car up but the the following morning the same trouble occurred.
At the workshop they carried out a new software updating (101 disc) but the the faults remain.
Please let me know if somebody has had the same problems. How did you solve them?
Thank you for your help.
Paolo
Post #36676 Thu Jun 01 2006 8:44am
Tim in Scotland
Paolo, how old is your RRS ? Is it one of the early ones as they seem to have had more than their fair share of electronics problems, most of which seem to be false alarms. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #36709 Thu Jun 01 2006 10:17am
wasnt it starting with some Batterie probs -cable on the carroserie ?
Post #36724 Thu Jun 01 2006 11:17am
RRS67
It has only three months life, and it has never had problems (battery or other) before....
Post #37346 Tue Jun 06 2006 1:10pm
Pelyma
Low battery throws up all sorts of weird and wonderful errors, but surely they would have checked that?
Post #37348 Tue Jun 06 2006 2:07pm
RRS67
It seems like there's an issue with the pressure sensor which gives a reading of 1800 bar. Anyway it happened with the engine running and while driving the car too. Ciao...
Post #37425 Wed Jun 07 2006 2:56pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
Paolo, I hope your issues have been taken care of by now, but I found this Tech Bulletin for RRS that may possibly apply to your problem:
SECTION: 414-01
Battery Junction Box Connections
AFFECTED VEHICLE RANGE:
Range Rover Sport (LS) VIN: ALL
CONDITION SUMMARY:
INOPERATIVE ELECTRICAL FEATURES
A customer may report a variety of concerns relating to warning lamps being displayed on the instrument pack or inoperative electrical circuits.
Cause: Diagnosis may indicate power supply problems. The complaints may be as a result of a poor connection or damaged / dislodged terminals in the battery junction box (BJB).
Action: Upon customer complaint of this type of electrical fault, refer to the Repair Procedure detailed in this bulletin for troubleshooting and corrective action.
PARTS:
Information Only
TOOLS:
YRW500030.............Wiring connector extraction tool (part of the wiring harness repair kit).
Buona fortuna e facci sapere come finisce (o come e' finita). Ciao e FORZA ITALIA!!!
Post #39046 Wed Jun 14 2006 12:27am
thanks umbertob - that was the thing i talked about...
Post #39066 Wed Jun 14 2006 9:39am
I had the very same problems last year - really annoying - turned out to be BATTERY problem and connections - so had new battery and replaced all connectors etc - now all OK Thumbs Up
Post #39077 Wed Jun 14 2006 10:52am
RRS67
I thank you all for your suggestions. Now I finally can tell you the problem which seems to be solved.
The engine electrical wiring has been fully replaced .
Thank you again and regards, Paolo[/color]
Post #43124 Fri Jun 30 2006 1:30pm
Andy
Ok, I've got to admit at reading the thread title wrong just then Embarassed Embarassed Embarassed 2002 Discovery Adventurer LE
1998 Freelander xedi
Ertl limited edition RRS model number 817
Post #43152 Fri Jun 30 2006 4:06pm
