Home > Technical > How to remove Starter Motor on 2006 4.2 V8 SC
lesmon
Trinidad And Tobago 2006 Range Rover Sport Supercharged Bonatti Grey
need some help with how to change/remove the starter motor on a 2006 4.2 V8 SC.
Had to tow the car home tonight as it would not start/tumble although the battery is reading perfect.
rgds
Les Totally Supercharged!!!
Post #338900 Fri Apr 06 2012 1:55am
Bobby
You asked about the Cooling Fan previously... did my suggestion help? Question Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #338904 Fri Apr 06 2012 4:39am
lesmon
Hi Bobby,
Still need to do the alternator work. The alt is still charging the battery, but the indash battery light comes on after about 15 mins of driving from cold, and then stays on for the rest of the day. My thinking is the the alternator is on its way out (brushes).
Yesterday, afternoon the car won't start - turning the ign I will hear a loud click (solenoid), but starter will not turn over. Got under and tried tapping the starter - but no luck. Battery is fine, and dash lights don't dull when ign is turned on (as what happens when there is a dead battery).
Rangy was brought home last night on a tow truck!!!
So I'm going to check the ground points now, but suspect the starter needs servicing.
I am after the removal procedure for the starter motor, please.
rgds
Post #338927 Fri Apr 06 2012 11:48am
acowx
United States 2006 Range Rover Sport Supercharged Rimini Red
This might help
http://www.cowxfinder.com/starter.pdf
Post #368425 Sat Jan 05 2013 1:56am
