Home > Technical > Low Coolant Level Alarm
Tim in Scotland
Just had mine serviced and on the way home from the dealer I got the bongs and "Low Coolant Level" warning. I returned to the dealer and the Service manager and I could not find an obvious leak. Work also carried out at the service included fitting the FBH which is loacted right beside the coolant header tank. The coolant level (with a warm engine) seemed to be OK.
Has anybody else had this warning - I wonder if it is something in the software upgrades calling wolf.....................
Later edit: Now the engine is fully cooled off I can see that the coolant level is below the minimum mark so either they forgot to top it up after draining the system to remove the header tank to fit the FBH or I have a leak................ I suspect the former! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #33860 Fri May 19 2006 6:19pm
grommet
United States
Search for "low coolant" -- bad sensors have known to cause issue on both RRS and LR3.
Post #33863 Fri May 19 2006 6:48pm
Tim in Scotland
Grommet you have a PM! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #33865 Fri May 19 2006 6:57pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
My coolant reservoir (with built-in sensor) was just replaced due to the same message, which first appeared several weeks ago. Since it was obvious there was no leak and the problem was with the sensor, I had this done with my recent scheduled service.
Post #33881 Fri May 19 2006 11:00pm
a bit off topic but on all our Jags we had the same problem - after a while the sensor gives up Rolling Eyes
i am sure its a FORD spare part !
Post #33890 Sat May 20 2006 6:00am
Tim in Scotland
All fixed after a trip to the dealer, so far no sign of any leakages and no more alarms! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #33915 Sat May 20 2006 10:42am
Bobby
What did they fix, Tim? Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #33922 Sat May 20 2006 11:25am
Tim in Scotland
They filled the reservoir up to the minimum level and gave me the remainder of the bottle of antifreeze already 50% diluted. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #33923 Sat May 20 2006 11:27am
Tim, now you've got your FBH I bet you're the only one amongst us praying for a cold snap!
Then again, you'll probably use your FBH all year round North o' Border! Wink Runner up - 2009 Best Avatar Award Sad
Post #33931 Sat May 20 2006 12:11pm
Tim in Scotland
I also had the Aircon fiddled with as the distribution seemed to be all the cold air to the drivers footwell and none to anywhere else! The problem with the FBH is testing that it is working OK!
And I'll have you know last week we have 5 days with temperatures in the mid 20's! It's been a bit different though this week, it has struggled to get above 18. It has rained nearly everyday and we don't need the water. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #33960 Sat May 20 2006 1:34pm
