Home > General > UK front license plate frame
buster04
United States 2011 Range Rover Sport Supercharged Santorini Black
Hello.. I am in the USA. I purchased a 2011 UK spec OEM Front license plate bracket/ mount. IT comes with 3 holes to attach it to the bumper. My question is how do you attach the plate to the bracket? The US spec have 4 holes for the license plate with threads. Thanks in advance
Post #329852 Sat Jan 28 2012 12:10am
Mike waldie
England 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Number plate goes on with either double sided tape or a self tapper either side of the plate
Post #330199 Mon Jan 30 2012 9:07pm
buster04
thank you.
Post #330234 Tue Jan 31 2012 4:09am
mrobbie
2006 Range Rover Sport Supercharged Bonatti Grey
...and be careful when removing the front plate on a cold morning if it has been stuck on with the double sided foam. Liklihood is that you will end up holding a plate and hald a mounting frame. Whistle
Post #331449 Tue Feb 07 2012 2:20pm
^^^ Good point Thumbs Up
If you need to remove something stuck on (eg number plate/lettering) dental floss/fishing line is a good idea to pass behind the plate/letters and gently 'saw' through the sticky pads.
The remaining pads can then be removed fully by a tar/glue remover. Smile ON THE WAY: BMW F21 M140i
Post #331451 Tue Feb 07 2012 2:23pm
mrobbie
wish I knew that last Friday morning Censored
Post #331452 Tue Feb 07 2012 2:42pm
^^^ oops Laughing ON THE WAY: BMW F21 M140i
Post #331453 Tue Feb 07 2012 2:46pm
