![]() | Home > Maintenance & Modifications > Replacing Black LR Badge on Steering Wheel |
| ChrisP Member Since: 26 Jan 2008 Location: Derbyshire Dales Posts: 1392
AFAIR it is just held in with 2 clips,you prise the old one off carefully with a screwdriver with a pad underneath to prevent any dints in the pad and then just glue the new one in with the glue provided. MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
| Linko Member Since: 10 Sep 2010 Location: Shropshire Posts: 61
I've done it. It's a nice easy job, you need a thin tipped flat head screwdriver to force the old badge out. It's held on with four spade prongs/thingys. It took some prising to twist and get it off.
| Steuart64 Member Since: 24 Dec 2009 Location: Aberdeen Posts: 539
Wayward heels? Ex- RRS HSE TDV6 07 Java Black, bi xenon, corner lights, side steps, tints, cool box, smoke side repeats, chrome "sport" boot sill Ex - Audi A4 Cab 3.0TDi Quattro Ex - Freelander2 SE TD4 Ex - CRV Auto |
| Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497
LOL - being a gentleman it would be rude to say... |
| chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950
There is a video showing you to remove it in this advert,
thanks - can't get that video to play though |
Strange worked fine for me when I bought one. What you want to do is get a "pincer" or terminal driver or something else small flat and blunt if you are not confident using a pincer and insert it at the top right corner before the curve of the oval ( the left side of the bend) and coax the badge hook out, then work your way round in clockwise direction on the other three hooks. This will release the badge, the replacement one will have no hooks and is secured using silicone sealant. |
| All times are GMT |
