Home > General > Low MpG on RRsport 2006 tdv6
sjf1
Hi
I am currently getting around 15.6 mpg around town, this used to be 22 mpg until i got my erg blanked. I also have a very light right foot while driving Razz
I am told it could be the turbo or intercooler hose, just not sure of the location for the hose. Is there anything else i can check?
thanks
Post #300038 Fri May 20 2011 12:30pm
SRE
Spain
Check
EPB
Map sensor
Air Filter In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #300045 Fri May 20 2011 12:56pm
stormer2009
United Kingdom 2009 Range Rover Sport TDV8 HST Santorini Black
check egr valves i had to replace both
Post #300497 Mon May 23 2011 10:18pm
sjf1
Cheers for the tips, I do have my erg valves blanked, so can this still cause the mpg to drop if they fail?
Post #300529 Tue May 24 2011 7:49am
stormer2009
you should have egr valves they make a difference to mpg
Post #300894 Thu May 26 2011 10:30pm
dazzerboy
England 2013 Range Rover Sport SDV6 Autobiography Bonatti Grey
hi ive got mine blanked and havent noticed a drop in mpg still get the same but i was told just the opposite that you should gain more mpg not lose Thumbs Up
Post #300972 Fri May 27 2011 3:44pm
DSL
Clean or change your MAP sensor. Thumbs Up
Post #300985 Fri May 27 2011 4:48pm
