Home > Maintenance & Modifications > Daylight Running Lights
rrs2010
Just fitted a set of DRL's on the motor, I have to say for the sum of £20 they are extremely good quality Mr. Green
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Cheers Paul
2006 TDV6 HSE - Cairns Blue
Tow Pack, Privacy Glass, PTI, DVD.
Post #291109 Fri Mar 04 2011 4:05pm
Hi Paul, Continuing on..
Have you wired them to run as DRL's or are they off the sidelight switch RRS gone
Post #291111 Fri Mar 04 2011 4:11pm
rrs2010
I was undecided how I wanted to wire them, I was going to wire them from a switched live under the bonnet but liked the idea of being able to turn them off if needed, In the end I decided to disconnect the front fog lights at the plug and fed DRL's with the fog light feed... So all I do is pull the switch out to put the front fogs on and my DRL's light up instead Mr. Green
I just hope it doesn't get foggy Laughing Cheers Paul
Post #291113 Fri Mar 04 2011 4:20pm
Laughing
and watch out at MOT time! RRS gone
Post #291114 Fri Mar 04 2011 5:00pm
scarey
you need to get a drl switch..i have one and it switchs my drl light on with the ignition and they go out when you put on your headlights..
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...K:MEWAX:IT
Post #291116 Fri Mar 04 2011 5:05pm
rrs2010
That's a handy gadget, I might get one Thumbs Up
Don't need to worry about MOT time, front fogs arn't a testable item Wink Cheers Paul
Post #291118 Fri Mar 04 2011 5:50pm
flydive
Probably cheaper to add a relay '08 RRS TDV8
Post #291120 Fri Mar 04 2011 6:07pm
I understand it as if you have got lights fitted no matter what lights they are, then they must work to pass an mot otherwise its a fail. Then maybe not in this case Big Cry
Ady
Post #291126 Fri Mar 04 2011 8:54pm
rrs2010
Not true mate, reversing lights are also not part of the MOT test Thumbs Up Cheers Paul
Post #291129 Fri Mar 04 2011 9:10pm
Sorry rrs2010, i stand corrected, i will have to check my facts before i post next time Thumbs Up
http://www.carsparefinder.co.uk/blog/the-mot-test-lighting/
Post #291130 Fri Mar 04 2011 9:16pm
rrs2010
No problem mate, your not the first to of thought the same Thumbs Up Cheers Paul
Post #291131 Fri Mar 04 2011 9:24pm
RRSNorway
Norway 2006 Range Rover Sport TDV6 HSE Zermatt Silver
nice looking DRL's
looking for some DRL for my 2006 HSE. Anyone seen a good set online?
how do you mount it the the lower bumper?
Post #349917 Thu Jul 05 2012 7:41pm
nicedayforit
You could always do what D3 and FFRR owners do and fit led halos inside the foglights.
Same foglight assembly on RRS.
DRL's
Post #349939 Fri Jul 06 2012 8:24am
RRSNorway
Don't like:) think the led strip looks more nice.
Post #349940 Fri Jul 06 2012 8:51am
saty
Re: Daylight Running Lights
Very nice indeed, very OEM.. Thumbs Up
Where did you get these from rrs2010.?
Post #349957 Fri Jul 06 2012 1:40pm
