Home > My Range Rover Sport > Stornaway Overfinch TDV8 |
m6totdv8 Member Since: 06 Dec 2010 Location: West Mids Posts: 51 |
Hi all
Sun Jan 30 2011 8:43pm |
That is very nice
Sun Jan 30 2011 10:43pm |
awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355 |
Lovely example RRS gone
Mon Jan 31 2011 11:33am |
kismet110 Member Since: 09 Oct 2010 Location: London Posts: 382 |
Stunning sir! |
Thu Feb 10 2011 12:18pm |
Cheer guys......was lurking on here for a good few months before I picked this one.
Thu Feb 10 2011 7:02pm |
I'd say thats normal, cane any diesel from a standing start and you will get some smoke and yours is no different than any other, Take note next time you are following other diesels.
Fri Feb 11 2011 9:31am |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 |
Try adding two stroke oil to the diesel that will stop the smoking.. |
Fri Feb 11 2011 9:47am |
No it doesn't Ady |
Fri Feb 11 2011 10:59am |
Yes it does - Due to the pollution control measures of the EC diesel-oil is nearly sulphur free and contains up to 5% of bio-diesel. Sulphur has the property to grease the high pressure injection pump and the injectors. Without sulphur, the reduced greasing property of the new diesel has already shown negativ impacts on the long-term stability of the injectors and the high pressure pump. The pump manufacturers have tried to react by lining the moving parts of the pumps with teflon or other suitable material. However, the long term stability is still not achieved as with the old (sulphor contained) diesel.
Fri Feb 11 2011 1:20pm |
So how many motor saws and lawn mowers do you know that run off diesel then? I thought they all run of petrol I still maintain my above statement, 2 stroke oil may reduce smoke but it doesn't stop it. But thank you for the science lesson.
Fri Feb 11 2011 1:51pm |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 |
Does anyone else add 300ml of 2 stroke oil to their diesel tanks? sounds pretty beneficial all in all.... |
Fri Feb 11 2011 2:06pm |
I do
Fri Feb 11 2011 2:50pm |
gilford Member Since: 07 Jan 2010 Location: Anglesey Posts: 542 |
Let me get this straight, you guys are adding 2 stroke to your TDV8 RRS
Fri Feb 11 2011 2:57pm |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 |
i think it should also be stated what 2T you can add ...... if you believe the hype
Fri Feb 11 2011 3:05pm |
