Home > Technical > U0405 error code after using BAS interface to read codes? |
awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355 |
Just read my recorded fault codes and this was the only one that popped up:
Tue Jan 11 2011 6:05pm |
Hi there, did you get it sorted? If so what was the problem?
Wed Jan 12 2011 9:23pm |
TBH because everything's working ok I've not bothered to look further!
Thu Jan 13 2011 10:28am |
Ahh the joys of owning a newer LR! RRS gone
Thu Jan 13 2011 11:12am |
jolleymike Member Since: 22 Aug 2008 Location: Wigan Posts: 55 |
Just got our TDV8 back from the stealers (parking sensors faulty) and have plugged my BAS box in to replace the standard map with the tuned one, all was good with the upload, started the engine after the process had completed all good there also.
Fri Jan 04 2013 7:09pm |
