Home > Maintenance & Modifications > frozen bits |
carbostar Member Since: 13 Jun 2010 Location: the north Posts: 27 |
Duno someone might know, bit disappointed that the washer system freezes up at the hint of frost;
Thu Dec 23 2010 10:30am |
You need to use virtually neat washer liquid then it doesn't freeze! 2005 Zambezi TDV6 - Gone but not forgotten
Thu Dec 23 2010 10:37am |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 374 |
James
Thu Dec 23 2010 1:10pm |
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 |
Sorry, by NW I mean Not Working.
Thu Dec 23 2010 1:16pm |
DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045 |
Try this stuff, should be good enough neat.
Thu Dec 23 2010 1:59pm |
bradtarga34 Member Since: 19 Jan 2010 Location: Walton-on-Thames Posts: 147 |
That's the stuff I use, very good. Otherwise I use the shell screenwash neat and have no problems freezing.
Thu Dec 23 2010 3:24pm |
Presently using Halfrauds normal stuff neat in my D3 neat. Says good down to -15c but in reality works down to -11c. Once that stuff is used up will get some Comma stuff, couple of places listed in Leatherhead. Mind you have "winter" mix level (1:4 conc ISTR) of Halfrauds stuff in SWMBO's D3, tends to be good enough for Surrey at around freezing. Any colder and we use my car with its heated steering wheel!! |
Thu Dec 23 2010 3:35pm |
You see i knew there would be a simple 'solution' a womans rule of thumb:if it has tyres or testicles your going to have trouble with it |
Mon Dec 27 2010 8:46pm |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
I use neat washer fluid from either Halfords or Costco. We have had -20 Degrees C several times this winter
Tue Dec 28 2010 2:53pm |
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 |
I assume that the headlight washer jets are the same fuse as the windscreen washer jets (F11) can someone confirm this, there does not appear to be a seperate fuse for them in the manual. |
Tue Dec 28 2010 7:02pm |
