Home > Technical > Raising/Lowering suspension |
JimboTD5 Member Since: 29 Jan 2010 Location: Hertfordshire Posts: 113 |
Sounds like it could be a ride height sensor, there was a TSB issued for this fault.
Thu Nov 18 2010 1:16am |
Nice But Dim Member Since: 15 Oct 2010 Location: Kent Posts: 61 |
Thanks Jim Its due to be booked in to be looked at, but is the raising from access to standard height suppose to be so jerky? or should i be mentioning to my dealer while looking at the ride height sensor, to check compressor to? Cheers. |
Sun Nov 21 2010 10:48pm |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 |
should be smooth mate, no jerkyness what so ever on mine |
Sun Nov 21 2010 10:54pm |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 374 |
Mine is smooth but does rear first then front.
Mon Nov 22 2010 1:46pm |
Thanks Guys
Mon Nov 22 2010 5:05pm |
Vadim Member Since: 20 Apr 2010 Location: London Posts: 855 |
Your suspension works as it should be: first rear then front. Also, keep in mind that you have two separate devices for rear and front suspension. The front has its own reservoir, not sure what the rear has, but its different. Sometimes, front reservoir needs to "re-charge" and therefore it may lift the front at a much slower rate than the rear side. That should not be of any concern as it is also, you guessed it, normal. This usually when you leave the car parked for some time. So do not worry, your suspension is fine. Vadim A. |
Tue Nov 23 2010 1:42am |
Not sure of the MY2010 system but ...
Its all one device. Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Tue Nov 23 2010 5:27am |
Thanks Guys
Tue Nov 23 2010 9:25am |
Hi Bobby, As matter of fact it is two separate devices on MY2010 models. But you are absolutely right, pre-2010 models had different design in this respect. I have an email from LPR regarding this matter which explains why front suspension can be slower than the rear, and the reason is as I explain above. Regards, Vadim A. |
Tue Nov 23 2010 6:37pm |
Hi Vadim,
Wed Nov 24 2010 3:51am |
Hi Bobby,
Wed Nov 24 2010 4:07am |
Here it is Bobby,
Wed Nov 24 2010 4:30am |
No worries, understood! Malaysia Boleh!
Wed Nov 24 2010 6:08am |
