Home > General > Sport Mode & Super Unleaded Fuel - Questions |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 |
1) No, no issue at all...If it's on the car standard, why shouldn't you use it! You spotted the only downside...lower mpg...
Wed Oct 27 2010 9:03am |
A lot of people use Sport mode in town, one of the downsides of Sport is that it locks out 6th gear (so in town that isn't a problem!) Don't forget too that ifd you want to you can also manually shift gears sequentially in sport mode too, no need to use it purely for overtaking/ fast get-aways.
Wed Oct 27 2010 4:57pm |
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 813 |
I would say that unless it's been mapped you wouldn't notice any difference on super really. They would have been mapped as standard to run on 95 as Tim has already said. Had to run my Evo on minimum 97 but that was due to it being tuned. |
Wed Oct 27 2010 5:14pm |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 |
Sport mode does not lock out 6th gear (on the TDV8 anyway) just that you have to get it up to about 170 - 180km/h before it will change up, as tested on the local autobahn
Wed Oct 27 2010 6:44pm |
ViewWise Member Since: 13 Mar 2008 Location: London Posts: 704 |
My car is always driven in sport. I get better mpg aswell than 'D' since it's learnt how i drive and there's less pedal movement and gear changes.
Thu Oct 28 2010 7:24am |
carlos50 Member Since: 04 Oct 2010 Location: North East Posts: 374 |
ViewWise
Thu Oct 28 2010 9:30am |
Baron Member Since: 23 Jun 2005 Location: Southener Posts: 529 |
Rarely use sports mode.
Thu Oct 28 2010 6:25pm |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 |
doesn't an engine need a knock sensor in order to take advantage of e.g. 99 RON? |
Thu Oct 28 2010 9:45pm |
RichardM Member Since: 25 Sep 2009 Location: Herts Posts: 745 |
I use it all the time, I much prefer the engine braking in sports mode. Its also so much livelier without any delay pulling away. In both the 3.0 TDV6 and in the TDV8 I've not had any problems with it going into 6th in sport, it just takes a while before it will change up. WINNER - 2009 ‘Just Doing What It’s Designed To Do’ Award 2010 TDV8 HSE Galway Green - Adaptive Cruise - Sunroof - Privacy Glass - 5 Spoke Alloys 2009 TDV6 3.0 HSE Buckingham Blue - GONE |
Fri Oct 29 2010 12:30am |
