![]() | Home > General > "VEHICLE LEAN WHEN CORNERING" |
gseum Member Since: 15 Feb 2010 Location: Germany Posts: 32 ![]() ![]() ![]() |
Hi,
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5643 ![]() ![]() |
Thanks for the reply gseum |
My RRS went to dealer on 27/08/2010 - they witnessed above warning on dash, plugged in computer and ordered parts.
Davidch Member Since: 22 Jul 2009 Location: Kent Posts: 40 ![]() ![]() |
Did you have any update on this? s mine is now doing the same 2005 car! RRS Supercharged HST Body Kit, 2010 Rear Lights, Fully Colour coded, 22 Rinspeed's |
Warning has never come on again so given up on this issue for now - has been suggested software update cured it |
RRS1STEDTI Member Since: 16 Nov 2010 Location: Basildon Posts: 2 ![]() ![]() ![]() |
Hi
rrspoland Member Since: 04 Dec 2008 Location: Warsaw Posts: 123 ![]() ![]() ![]() |
I have my car for almost 3 years now. I get this warning from time to time, 3-4 a year, mostly when it is cold. But when I switch off the engine and start again it goes away.
Yes just don't fancy giving it to them, for them to muck around with. Same across the board unless you buy a new car every 6 months they don't care anymore! ![]() HST Body Kit, 2010 Rear Lights, Fully Colour coded, 22 Rinspeed's |
lord Fenham Member Since: 05 Mar 2010 Location: tynemouth, newcastle uk Posts: 53 ![]() ![]() |
Get the dealership to hire you a similar vehicle or better for your trip. Do not stand for anything less.
Hi
Tre4 Member Since: 14 Sep 2012 Location: S.Warwickshire Posts: 29 ![]() ![]() |
Exactly same thing last night on my 2011; Stopped off on way home from work for a short shop, and on firing up the electrics I saw the amber warning. Turned off then on again after waiting 10 secs, still there ![]() Drove home, leaning in corners, parked up and went through the self test a couple of times to see if would clear. Unfortunately not. Manual out and read of relevant section. Seek maintenance....(should say, have a quick look at RRSSPORT.CO.UK) so had a quick search and found this thread. A little reassured that it may clear of own accord, but planned to book in to dealer next day. Forced to drive to work in RRS, as wife needed her car, doesn't it feel different without the lean control! Strangely enough, got to work and had to shut down to get out and check through security and when I went to start up again, the warning was gone !?!? Depending what happens on the way home tonight, may still book into dealer to have a look. |
c4skp Member Since: 10 Jul 2011 Location: Bournemouth Posts: 48 ![]() ![]() |
My 2012 had this sunday
All fine on way home tonight, keeping a close eye out still!
Low fuel sounds like a coincidence |
