Home > Technical > Restricted Performance - red triangle warning light |
Landlord Member Since: 26 Sep 2006 Location: Hampshire Posts: 607 |
Mine went into restricted mode yesterday and has a slight whistle, will check the hose today. Typical as its 11 days out of warranty
Mon Dec 24 2012 6:16am |
pnchbeckr Member Since: 23 Dec 2012 Location: Surrey Posts: 2 |
The hose that was the fault in my case is located behind a pop-off panel, accessible from underneath in the near side wheel well (turn lock completely to left to access; pop-off panel has four "raw plug" type fixings that remove by first extracting the centre core of the fixing. Warning - apparently older fixings will likely break and need to be replaced as they get brittle with time.)
Mon Dec 24 2012 9:55am |
At dealers now. It appears to be a stuck turbo solenoid which is jammed in the open position. One hour to replace and £180. Hopefully this will sort it, will update once I'm out of here and driven home. MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
Mon Dec 24 2012 1:33pm |
Drove home, fault appears cured MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
Mon Dec 24 2012 3:35pm |
Driving along the M3 today at 4.20pm, near Basingstoke, 35miles from home, outside lane 70+, red warning light, engine fault, complete shutdown, not even limp home mode, coasted to hard shoulder. Tried engine, would turn over but not start
Tue Feb 12 2013 3:14am |
awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355 |
that's shocking Landlord RRS gone
Tue Feb 12 2013 4:44pm |
That is poor service form the AA
Tue Feb 12 2013 4:54pm |
Hate to see what a low priority call is Mike
Tue Feb 12 2013 8:16pm |
Some silver lining to this story......
Wed Feb 13 2013 12:05am |
big pimp Member Since: 09 Jan 2010 Location: northern ireland Posts: 548 |
typical - a week or so before i hopefully get my new sport, and I just got this message today.
Sun Sep 29 2013 12:12pm |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1826 |
This restricted performance warning plus red triangle happened to me last night. 2 mins after leaving home parked car up at a friends very near, left it for a while and was all ok again. Should i worry? SVR 2018 in Santorini Black. |
Sun Oct 06 2013 10:14am |
easyrideruk Member Since: 19 Sep 2010 Location: Stowmarket Posts: 5 |
I had this issue come up on mt 2010 RRS Lux and all l did was insert the OBD tool and reset all error codes. All seems okay again. EasyriderUK |
Mon May 25 2015 9:58pm |
tonytiger Member Since: 14 Sep 2013 Location: St.Neots. Cambs Posts: 308 |
Easyrideruk..... Still ok??
Sun Jun 28 2015 4:49pm |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 |
Had this come up on mine today pulled over stopped and started again all OK. I drove to my indie plugged in and fault showed air flow sensor it's been cleared on his diagnostics and told me to go for a good drive and return in the morning for a re-scan and double check. |
Mon Nov 16 2015 7:26pm |
