Home > Technical > MY2010 iPod Connection Problem
ngins
United Kingdom 2010 Range Rover Sport Supercharged Santorini Black
Hi All,
Found an issue with my iPod, I was regularly getting issues with it only connecting to half the speakers, then getting in a destructive loop saying device not connected, then connecting then saying not connected again. I have finally found out that it seems to be an issue with the connector between the bottom of the armrest lid and the base of that unit going into the main car (into the transmission tunnel) (If I wiggle it around I can make it connect/disconnect). Anyone else had any issues? - any idea if LR are going to rip apart the interior to fix this or is it a relatively localised part to fix/replace? I am glad I have found the problem but I am reading having the console ripped apart.
N MY2010 RRS 5.0 S/C Santorini Black, 5 Spoke Diamond Turned Alloys, Privacy, Logic7, iPod, Cameras
Post #273439 Mon Aug 09 2010 3:10pm
Endjin
Scotland
It's under warranty so I'd make them fix it regardless! 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #273442 Mon Aug 09 2010 3:12pm
ngins
true - but I have had other companies 'fix' stuff under warranty and regretted it - if its an easy job then I am not too worried but if it looks like a major internals ripout then I might just put up with having an 'iffy' connection.... MY2010 RRS 5.0 S/C Santorini Black, 5 Spoke Diamond Turned Alloys, Privacy, Logic7, iPod, Cameras
Post #273779 Fri Aug 13 2010 3:10pm
and if they F up the process make sure they fix the mess - use the warranty it's want it's there for. 2005 Zambezi TDV6 - Gone but not forgotten
Post #273787 Fri Aug 13 2010 3:54pm
Endjin
Scotland
Abso-bloomin-lutely, couldn't agree more Thumbs Up 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Post #273792 Fri Aug 13 2010 5:37pm
ngins
i hear you guys, just dreading it! MY2010 RRS 5.0 S/C Santorini Black, 5 Spoke Diamond Turned Alloys, Privacy, Logic7, iPod, Cameras
Post #273794 Fri Aug 13 2010 5:44pm
acaine2003
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
Re: MY2010 iPod Connection Problem
ngins wrote:
Hi All,
N
ngins.
I have had exactly the same problem with the Ipod lead only working on one half of the speakers!!! It due to go back to the dealers in just over a week. I will let you know the outcome
Post #273909 Sun Aug 15 2010 4:23pm
Lookers Park Royal
Let them try another lead from a demo etc first.
Post #273916 Sun Aug 15 2010 6:39pm
acaine2003
The dealership has already sent me out a new iPod lead but again no joy, is it a big job or just a case of replacing the coolbox lid? As well as that the car has a small judder at around 65mph so that needs to get checked as well! I have all the luck
Has anyone else noticed this on the new 2010 model?
Post #273922 Sun Aug 15 2010 8:20pm
ngins
@acaine2003 - thanks - will be great to see how you get on. (no judder by the way)
@lookers park royal - its definitely not the lead - tried a couple of replacements - its the piece of cable between the hinge of the coolbox/armrest lid and the main body of the car as if you wiggle it it connects/disconnects the iPod or only connects half the speakers/no sub etc etc MY2010 RRS 5.0 S/C Santorini Black, 5 Spoke Diamond Turned Alloys, Privacy, Logic7, iPod, Cameras
Post #273946 Mon Aug 16 2010 10:49am
ngins
@acaine2003 - any update - did they replace your coolbox/console lid?? do something else? did it fix the problem? how long was it in for? Hope it all went ok! Awaiting your news before I book mine in! MY2010 RRS 5.0 S/C Santorini Black, 5 Spoke Diamond Turned Alloys, Privacy, Logic7, iPod, Cameras
Post #274589 Wed Aug 25 2010 12:27am
ngins
just as an update on this. Finally got around to getting this sorted, garage did a great job, I no visible signs that it was replaced other than the ew lead looks a little longer over the hinge than the old one, seems to have fixed the issue! For anyone interested apparently its a bit of loom that goes fomr the connector in the glove box to the main unit back to the arm-rest. MY2010 RRS 5.0 S/C Santorini Black, 5 Spoke Diamond Turned Alloys, Privacy, Logic7, iPod, Cameras
Post #279567 Fri Nov 05 2010 3:59pm
OrhanY
2011 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Does the iPod shuffle is available in 2010 models? 2011 Range Rover Sport HSE 3.0TDV6
Bali Blue / 19w. / Hybrid TV
2008 BMW 520d
Alpin White / Black
Post #281062 Wed Nov 24 2010 8:34pm
ngins
sorry - i ionly have iPhone 3/3GS/4 and iPod touch which all work fine.... MY2010 RRS 5.0 S/C Santorini Black, 5 Spoke Diamond Turned Alloys, Privacy, Logic7, iPod, Cameras
Post #281112 Thu Nov 25 2010 6:33pm
