Home > General > Load cover doesn't fit properly??? |
rangrov Member Since: 23 Jul 2010 Location: lancashire Posts: 84 |
I sugest you go round the main stealers and check what they look like in theres, i take it yours is a sport, you could have a cover off another model I.E freelander etc. RANGE ROVER 3.6 TD V8 HSE ZERMATT SILVER BLACK LEATHER. AC COBRA 5.7 V8.................. LIVE FOR TODAY COS TOMORROW MAY NEVER ARRIVE,,,, |
Sun Aug 01 2010 6:20pm |
Or worse still a Disco3 or 4! At least it isn't out of a FFRR, they have a rigid loadspace cover that folds up 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sun Aug 01 2010 7:28pm |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 |
On mine if you pull to locate in slots for half opening it is the same as yours pull to fully out to cover boot and the end tapers then it completely closes the gap. Have you pulled fully out??
Sun Aug 01 2010 8:53pm |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
@Panda
Mon Aug 02 2010 11:27am |
From the photos the cover is a lot shorter than the one I have, mine is not easy to remove and never vibrates or rattles. Maybe a visit to a dealer to look in the boot of their used cars might resolve the problem, but I suspect that Big DJ nay have an F2 or D3 or D4 load cover 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Aug 02 2010 12:18pm |
BIG DJ Member Since: 25 Oct 2009 Location: Heathrow Posts: 813 |
That's correct Endjin
Mon Aug 02 2010 7:08pm |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 |
are you sure the spring is not bust in one of the end caps? MY10 TDV6 SE (debadged ), Santorini Black, Flappy paddles, Privacy Glass, 20" Stormers, Mudflaps!
Mon Aug 02 2010 7:23pm |
Na definatly too short. There's a sprung bit on the end that holds it in place. |
Mon Aug 02 2010 7:26pm |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 |
As a comparison my FL2 shelf is 128cm wide and looks like yours |
Mon Aug 02 2010 7:51pm |
Thanks npinks will give it a measure |
Mon Aug 02 2010 8:00pm |
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 |
Looks like you've got a Freelander loadspace cover there! |
Tue Aug 03 2010 8:46am |
Thanks James. Emailed Matthew and gonna pop in when passing for him to have a look. |
Tue Aug 03 2010 9:50am |
Mrs Endjin has a Freel2. I'll try her load cover in my RRS tonight and see if it looks like yours. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Tue Aug 03 2010 12:59pm |
measured mine today 1350 mm then measured cover and it was the same then woke up. Not including spring clips
Tue Aug 03 2010 4:43pm |
