Home > Maintenance & Modifications > Problem with removable Tow Ball
Endjin
Scotland
I can't seem to get my removable Tow Ball unit to fit into the receptor. It goes in and appears to click in place
but the green lock handle doesn't completely cover the red indicator ring and therefore I can't lock the unit and
remove the key! I have made sure there is no crap in the mechanism and I have used as much force as I can to push the unit up, but I still can't get it to fit. I have also checked that the locking mechanism on the Tow Ball all works perfectly off the car, so it has to be a fitting issue. Anyone had this problem and any ideas how to resolve it Confused 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #265010 Tue May 04 2010 1:02pm
purple people eater
on the mY10 mine has been a little more troublesome than the 56 plate, but have just persevered until it works, dont know why it wont "click" first time, or what I have done different when it does work, need a few more trips out purple people eater
There are no good days, just some days that are not as bad as others!
Gone RR 4.0 P38 Autobiography MY99 Red ( Evil or Very Mad money pit)
Gone Big Cry RRS MY06 2.7TDV6 HSE Rimini Red
Gone RRS MY10 3.0TDV6 HSE Bali Blue with lots of bits (never grew to love it)
Here Now - 3.6 TDV8 FFRR OVERFINCH Stornoway Grey - loving it x
My work car Ford Mondeo 2.0 TDci Zetec auto Estate in Silver
Post #265068 Wed May 05 2010 12:01am
purple people eater
Not lost a Caravan yet Thumbs Up purple people eater
Post #265069 Wed May 05 2010 12:02am
purple people eater
Well actually yes, i did drop one outside my drive once when i had not correctly secured the hitch, but not on a RRS Embarassed purple people eater
Post #265070 Wed May 05 2010 12:03am
Endjin
Scotland
Finally got the damn thing to locate properly! Took much pushing & wiggling and a few choice words combined with a kick & then it suddenly clicked in to place. Thumbs Up The problem seems to be the big locking bolt that pops out the rear of the unit and is obviously a very neat fit with it's receptor hole. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Post #265089 Wed May 05 2010 10:20am
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
Its a fight everytime you want to fit it or take it off.
Think you have it sussed, then it changes its mind again.
Censored Censored Censored Censored
Got mine and off fairly quick today but could I get the key out, hell no Evil or Very Mad
Designed by the Devil if you ask me Exclamation
Post #265169 Wed May 05 2010 8:52pm
Texstar
Lespes, in case you weren't aware, the key should not be able to be removed from the lock unless tow hook is fitted,(or you trigger it as if it were fitted), and in the locked position. Wink Hope that's not too late, and that you haven't busted it . RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #265172 Wed May 05 2010 10:24pm
Endjin
Scotland
Yep, It's a real B Censored tch Evil or Very Mad Now I know why I see so many with "removable" Tow Bars that are just left fitted! Think I may be joining the ranks of those that just can't be arsed taking the damn thing off!! I've got better things to do with my time...... like maybe contemplate the fluff in my belly button Whistle Wink 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Post #265191 Thu May 06 2010 9:20am
lespes
Quote:
Lespes, in case you weren't aware, the key should not be able to be removed from the lock unless tow hook is fitted,(or you trigger it as if it were fitted), and in the locked position. Hope that's not too late, and that you haven't busted it .
no its all OK.
Always remove key when putting back in storage, thats how it came Exclamation
If leave key in will not fit in my storage place, to big, sometimes its a peice of cake , more often not Exclamation
Post #265320 Fri May 07 2010 12:21am
