Home > Technical > Excessive body roll
avartis
2006 Range Rover Sport TDV6 SE Rimini Red
Excessive body roll
Hi,
I've just replaced my front lower arm bushes and I've reduced my steering wheel shimmy. Also replaced the ARB bushes.
The only problem I have now is that on uneven surfaces my car's front side wobbles from side to side.
Are these the symptoms of upper arm bushes or anti roll bar links?
I should mention I don't have dynamic response.
Thank you
Post #264626 Thu Apr 29 2010 3:56pm
avartis
It seems my shock absorbers inside the air struts are going bad.
Could someone please post the instructions for dissasembling the air strut and changing the shock?
Thank you!
Post #264801 Sat May 01 2010 7:58am
