Changing fascia/trim
Hi,
I'm currently changing the rhodium/silver trim bits in my RRS to piano black. I've done the door panels and intend to replace the centre console side pieces that run either side of the gear stick area. It looks as though these pieces slot inside the upper fascia piece that runs between the radio control section. Do I need to take that whole part out or can I just pull the bit I want to replace out?
These diagrams are the only I can find and seem to suggest I can just pull the bit out:
This document doesn't have any written instruction and I don't have any double sided tape which I think is what they're indicating? I was hoping i can just pull the old ones out and slot new ones in.
Any advice would be appreciated!
ps. if anyone wants my old trim pieces get in touch they will be available soon (hopefully)!
Thanks.
Tue Apr 27 2010 2:49pm
kman
