Home > Technical > Sat Nav Aerial - where is it?
robinc
United Kingdom 2010 Range Rover Sport 3.0 TDV6 SE Nara Bronze
Hi guys
Been having intermittent problems with my satnav for a while. Keeps losing the GPS signal, especially when it's raining. Having fiddled around with every connection and even changed the DVD disk, I eventually bought a cheap after-market magnetic GPS aerial, stuck it on the roof and plugged it into the back of the satnav unit under the passenger seat in place of the normal aerial connection. Bingo, everything working perfectly again Very Happy
Whilst this has temporarily fixed the problem, I would like to locate the original GPS aerial and fix it or replace it. I heard a rumour that it's somewhere in the tailgate spoiler?
Does anyone know if that's correct and if so, how to gain access? I can't see any easy way to get into the spoiler but maybe I'm missing something obvious.
Any tips gratefully received.
Robin
Post #264269 Mon Apr 26 2010 1:33pm
Tweaky
I always thought it was in the sharks fin on the roof. However i am not sure if i have been told that of if it is just me assuming that is where it is.
Post #264273 Mon Apr 26 2010 1:54pm
Warren G
Pretty certain its the bit on the roof......
Post #264275 Mon Apr 26 2010 2:17pm
Endjin
Scotland
That's correct Thumbs Up The Roof Fin housed both the Sat Nav & Mobile Phone Aerials until the 2010 model
which now only has the Bluetooth Connection for phones and hence a smaller roof aerial for the Satnav alone. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #264276 Mon Apr 26 2010 2:47pm
biffo
United Kingdom 2013 Range Rover Sport SDV6 HSE Firenze Red
I always thought the Sat Nav aeriel was located in the high level brake light housing. SAME S**T DIFFERENT DAY
Post #264278 Mon Apr 26 2010 3:02pm
Endjin
Scotland
No, It's on the roof as per the pic on Warren G's reply. The one he's shown is the pre 2010 version. The current ones are smaller due to the lack of the Mobile Phone part. Cars without Satnav Do not have the Roof Fin fitted at all. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Post #264283 Mon Apr 26 2010 4:50pm
robinc
Ah ha. So it looks like I'll have to replace the whole sharks fin antenna assembly? Is it easy to remove? I guess I'll need to pull the headlining down at the back in order to gain access to the underside. Anyone done that?
Might be easier just to stick my new magnetic aerial on the roof just behind the sharks fin and route the cable through the top of the bootlid and splice it in to the cable under the headlining, assuming I can get access to it.
I shall report back once I've investigated further.
Thanks for the comments so far....
Post #264286 Mon Apr 26 2010 5:16pm
Shrinky
You will have to pull the headlining down then it unbolts. This pic might help Thumbs Up
 Global Warming.... I'm luvvin it.
Post #264296 Mon Apr 26 2010 8:51pm
Bobby
I have this in my Gallery... would it help? Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #264322 Tue Apr 27 2010 12:26am
MAW
My current RRS is a MY09 but it is the shallower fin - if the BT is not in there now where is it?
Post #264364 Tue Apr 27 2010 1:03pm
Bobby
Your BT phone module is hidden between the headliner and the roof. Wink Malaysia Boleh!
Post #264366 Tue Apr 27 2010 1:16pm
Endjin
Scotland
I wasn't reffering to the BT module. The Aerial Fin on the roof of pre 2009 cars held a seperate Aerial for the Mobile Phone which was connected when your mobile was physically plugged in to the Phone Cradle which used to be located under the flip cover of the centre console tray/fridge assembly. When the phone was connected via this cradle it did not use BT at all. Since the 10MY edition of the car (maybe also 09MY, but I'm not sure) it has been done away with and the car now ONLY uses BT hence the smaller roof top Fin.
Hope this clears up the confusion. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Post #264488 Wed Apr 28 2010 10:17am
robinc
Shrinky, that's a very helpful pic, thanks for posting it. Do you happen to know which cable is the satnav/gps aerial, pink or blue?
Robin
Post #264503 Wed Apr 28 2010 12:45pm
MAW
Ah - it was the MY09 - 10 thing that threw me
Post #264508 Wed Apr 28 2010 1:12pm
MAW
Thank you Thumbs Up
Post #264509 Wed Apr 28 2010 1:12pm
