Home > Technical > Check engine - Amber Warning Light |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
Try turning off and back on........may just be a software glitch. If not resolved do that a few times and then I'm afraid you may need a dealer. TDV6 - gone
Fri Feb 05 2010 3:40pm |
gordon kerr Member Since: 14 Jan 2010 Location: Bedford Posts: 49 |
Mine did this in the recent very cold weather (not necessarily any direct connection but it went off again when it warmed up) LR specialists computer showed fault as the EGR valves (apparently quite common). No other real symptoms except the performance seemed a bit "flat". Light went off when it warmed up but it had been booked into main dealer by then and they changed the valves yesterday (at least they say they did how would I know? All dealt with under warranty). Can't say as changing the valves has made any obvious difference and had it not been under warranty the LR specialists preference would have been to blank them off completely. Waiting for the light to come back on now Gordon Kerr
Fri Feb 05 2010 4:05pm |
samd Member Since: 21 Sep 2009 Location: Derbyshire Posts: 118 |
Thanks both - turned off and on quite a few times - no joy. Stealers it is then! |
Fri Feb 05 2010 4:37pm |
