Home > Technical > 2006 TDV6 WHAT MAKES THE ENGINE ?
issy-olivia
United Kingdom 2006 Range Rover Sport TDV6 HSE Zambezi Silver
Hi just a few more questions about my newly bought rr sport ? who makes the engine ? any known comern faults ? cambelt change milage or chain ? oh and thanks for all your support so far top forum cheers guys !! Very Happy 2006 RR SPORT TDV6 HSE SILVER 22 STORMERS RUNNING BOARDS FULLY COLOUR CODED WIND DEFLECTORS CHROME MIRRORS WINDOW TINTS
Post #253750 Thu Feb 04 2010 9:16pm
Texstar
TDV6 is a joint Peugeot / Ford effort, built at the Dagenham engine plant Shocked I believe. Cambelt and HP fuel pump belt require changing at 105,000 miles or 7 yrs whichever is sooner,under normal operating conditions.A couple of quite common faults.......EGR valve problems, some have had Turbo failures Rolling Eyes or if lucky sometimes just a split intercooler hose. RRS TDV8 Buck Blue (no, not now in my dreams). ..........D3 TDclankety clankV6 ............BMW 318i
Post #253756 Thu Feb 04 2010 10:11pm
MAW
Laughing
Post #253783 Thu Feb 04 2010 11:51pm
Bobby
I don't know how who makes the engine makes any difference but I hope this helps...
Quote:
The TdV6 engine is a 2.7 liter, direct injection, six-cylinder diesel engine having two banks of three cylinders, arranged at 60 degrees to each other. There are 4 valves per cylinder, which are operated by two overhead camshafts per cylinder bank. The engine emissions comply with ECD3 (European Commission Directive) legislative requirements and employs two catalytic converters, electronic engine management control, positive crankcase ventilation and exhaust gas recirculation to limit the emission of pollutants. The unit is water cooled and turbo-charged. The fuel injection system features common rail technology.
The cylinder block is manufactured in Compacted Graphite Iron (CGI) and is coupled with a separate aluminium ladder frame to provide a lightweight, compact and very stiff bottom end of the engine. The cylinder heads are cast aluminium with a moulded plastic camshaft cover. The single-piece oil sump is formed from stamped steel. The cast iron exhaust manifolds are unique for each cylinder bank and a moulded plastic acoustic cover is fitted over the upper engine to reduce engine-generated noise.
TECHNICAL FEATURES
The technical features include:
* 60 degree 'vee' 6 cylinder engine with a CGI cylinder block
* Plastic cylinder head cover
* Two light, high strength, aluminium cylinder heads
* 4-valve technology with centrally arranged fuel injectors
* Steel roller rockers with hydraulic lash adjusters
* Twin plenum intake system integrated with the camshaft cover
* Variable Geometry Turbocharger
* Common rail direct fuel injection system
* High pressure fuel pump
* Gallery cooled pistons with a central crown bowl
* Two electronically controlled Exhaust Gas Recirculation (EGR) valves
* Two EGR coolers
* Exhaust re-treatment by means of a diesel specific oxidation catalytic converter and primary catalytic converter
* Cooling fan with electro-viscous clutch drive.
Cool Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #253786 Fri Feb 05 2010 12:03am
Laughing
Post #253806 Fri Feb 05 2010 8:39am
