Home > Technical > Just got back from the dealer
Zipperman19
United States 2006 Range Rover Sport 4.4 V8 HSE Buckingham Blue
I just got back from the dealer and I'm fairly Censored off:
Just as I expected the annoying problems I had were either "Not Found" or "Operating to Spec"
1. I have a rear brake squeal which has been getting progressivly worse. I showed them the bulliten and they told me that if my clips broke the cars would be making a horrible noise whenever braking and the pads and brake assembly would turn blue. Is this true?!? I thought those were wrost case scenarios and my car was just getting there.
2. They denied any knowledge of a passenger door rattle fix. I just searched with no luck. Does anyone have the bulletin on the passenger door speaker padding and rattle problem.
Thanks guys I just need to calm down.
Post #16301 Wed Mar 08 2006 12:05am
thebishman
United States 2006 Range Rover Sport Supercharged Bonatti Grey
Don't know about the rear brakes, but one of the other posters, (I'm sorry I can't remember who), suggested this to take care of the passenger door rattle. Tighten the Phillips head screw in the lower plastic interior panel, (take care not to over tighten), and then place the warranty book/portfolio folder in the storage area. Problem solved, no rattling since.
Bish '06 RRS S/C Bonatti Grey/Ebony/Cherry with RSE; PTI; Electronic Rear Diff and Sirius Sat Radio.
Post #16305 Wed Mar 08 2006 1:22am
canaryman
Germany 2006 Range Rover Sport TDV6 SE Cairns Blue
Zipperman. What do you need to calm down about?Were you treated poorly by the dealership?Have the problems you mentioned caused any life changing experiences? No? Just call the manager, ask to meet him and then tell him what your problems are.
If your brakes had failed and you had ploughed into the rear of one of those cars that you make in the USA that explode on impact or your car had left you stranded in the Arizona desert or the dealership had mis-treated you then I would understand your need to "calm down"
Post #16315 Wed Mar 08 2006 9:32am
Zipperman19
No i'm fine. It's just really annoying that I brought to car to the dealership and drove their crappy rental car for a week and not even half the things I complained about were fixed. I just got the coolant level warning again. They told me they just replaced the tank. This stuff is getting annoying. All I want them to do is fix the car.
Post #16437 Wed Mar 08 2006 4:28pm
same engine as my Jaguar XKs right ?
if so - they have all this problem !
WINNER - 2009 ´┐ŻBest Avatar´┐Ż Award
Post #16439 Wed Mar 08 2006 4:30pm
