Home > Technical > HDC Reported Fault
dans1v
HDC Reported Fault
I wonder if anyone has had this problem....every time of late and it seems sometimes to be linked to when its really cold that on start up a fault flashes up saying "HDC fault" im sure there is a bit more text to it but thats the basis of it. Then it dissappears immediatly and all looks normal and there is no fault logged in the computer and the HDC works fine.
Any ideas why this might happen?
Regards
Dan[/b] Java Black RRS HSE TDV6 Stormers, tints, steps the usual stuff..
Post #247365 Fri Jan 01 2010 4:32pm
MikeS
Australia 2005 Range Rover Sport 4.4 V8 HSE Tangiers Orange
I'm getting the same message flash up occasionally on mine, but after using the HDC yesterday I know there's no fault in it, so I'm a bit puzzled as to why it's coming up. Having only had the car 2 weeks I'm just adding it to the list of 'issues' to be looked at by Stratstones when I give it back to them for a day to sort everything out, be great if I could give them a definitive "you need to do this....." if it's a known problem area.
Mike Ex-G4 Challenge RRS HSE, BV55 YZE. Subtle shade of orange ! Now registered YZE481 G4RRS in Melbourne.
Post #247379 Fri Jan 01 2010 6:19pm
dans1v
i would agree lets see if any of the others come up with any ideas for us? Java Black RRS HSE TDV6 Stormers, tints, steps the usual stuff..
Post #247406 Fri Jan 01 2010 10:23pm
shuzzy
I have recently started to get the same thing, most of the time when I start it up after it's been parked up for a while. It will flash up for a couple of seconds that I have a HDC fault, but then it disappers straight away. Looks like it mught be one of them RRS 'chracteristics' again......
Post #247419 Fri Jan 01 2010 11:30pm
ELD70
I am sure this is related to a low battery voltage on startup. Has anyone tried charging their battery or replacing it?
This is a common post on on Disco3 site and if a battery is low or weak can throw up all sorts of faults on start up.
Post #247422 Fri Jan 01 2010 11:58pm
shuzzy
I had a new battery fitted a few months ago, so this shouldn't have any bearing on things now.
Post #247426 Sat Jan 02 2010 3:06am
I have had this over on Freel2 and on the FL2 it's related to a sensor on the haldex unit and it only appears in very cold weather, but on Disco3 it was related to battery issues
Post #247432 Sat Jan 02 2010 10:13am
PauloAmore
Scotland
chaps...
had exactly the same last year.
A new battery solved everything. 2022 P440e AB
Post #247472 Sat Jan 02 2010 4:42pm
Tim in Scotland
Also don't forget that low temperatures can kill a battery overnight so if you have had very low temperatures (mind you we have had down to -12c here some nights recently but my RRS has had no problems starting, unlike my 90 which is garaged and the battery can only just start the car after a really cold night, but after a run and the car's inside has warmed up then it starts no problems at all) then that will reduce the efficiency of your battery and could cause these warnings to show up 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #247485 Sat Jan 02 2010 6:01pm
MikeS
Looks like a new battery then. Mine popped the message up today after a particularly cold night and 'someone' leaving the interior reading lights switched on overnight Rolling Eyes Will have to see if I can get the dealer to swap it under their warranty (doubtful, but worth a try). Ex-G4 Challenge RRS HSE, BV55 YZE. Subtle shade of orange ! Now registered YZE481 G4RRS in Melbourne.
Post #247510 Sat Jan 02 2010 8:02pm
The doc
Cool
Post #247539 Sat Jan 02 2010 11:10pm
