Home > Maintenance & Modifications > Replacing the steering wheel |
Simon Sport Member Since: 14 Feb 2009 Location: Somewhere on the road Posts: 10 |
It's time to replace my worn out and rotting steering wheel. Four screws at rear removed and ........?? What next please!!!!
Mon Oct 12 2009 3:09pm |
The new "smooth" OEM steering wheel?
Mon Oct 12 2009 3:31pm |
Have gone for the original grained wheel, thought the 'smooth feel' contrasted too much with the other grained areas ie; dash etc
Mon Oct 12 2009 3:45pm |
There's a "special" tool required to remove the airbag and switch pack I believe - not sure if a dealer would supply this or not.
Mon Oct 12 2009 3:50pm |
Ok thanks. As it needs a special tool I'll leave it to get replaced at the service in a couple of weeks.
Mon Oct 12 2009 4:16pm |
sid Member Since: 21 Aug 2007 Location: northants Posts: 45 |
Steering wheel airbag removal tool.
Mon Oct 12 2009 4:54pm |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 |
£20
Mon Oct 12 2009 5:44pm |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1936 |
Have a search around, I am sure that Bobby has posted the procedure before, I remember seeing it somewhere |
Mon Oct 12 2009 10:02pm |
Once again, the pikeys prove themselves more useful than us 2009 Outstanding Contribution Award - Joint Runner Up 2009 'Tech-Head Of The Year' Award - Runner Up Like it here? Then Donate to RRSPORT!! |
Tue Oct 13 2009 8:58am |
gianluca Member Since: 18 Mar 2009 Location: Potenza Posts: 136 |
I had it done by the service.
Tue Oct 13 2009 12:06pm |
2nd Rower Member Since: 12 Nov 2007 Location: Upside Down Posts: 1382 |
My worn steering wheel was replaced under warranty... for some reason they also replaced my perfectly good airbag at the same time?! |
Tue Oct 13 2009 1:18pm |
