Home > Technical > Blackberry pairing with MY10 RRS |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1936 |
My new Blackberry Curve 8900 paired fine with my MY09 RRS even though a VIN check on the LR website said that it wouldn't transfer the phone book....it did.
Wed Oct 07 2009 3:44pm |
Pelyma Member Since: 29 Sep 2005 Location: Sussex Posts: 1497 |
Buy an iphone Porsche Cayenne S Diesel 66 Plate |
Thu Oct 08 2009 3:45pm |
cheesy Member Since: 08 Oct 2009 Location: Chesterfield Posts: 33 |
Hi SILVERSPEEDRRS I've got Blackberry 9000 and same happens to mine and tried all sorts but no good!!!
Thu Oct 08 2009 8:22pm |
JeffW Member Since: 06 Oct 2009 Location: Washington State Posts: 5 |
My Blackberry 9000 worked great with the 2010. The phonebook entries look fine. I had upgraded the blackberry to the latest OS, though, which I think may be the trick, because I read that was necessary in the case of the LR2/FL2, which uses the same (or similar) system. At the time, my carrier (AT&T) didn't have the latest OS available, so I just downloaded from a carrier from China. Works great. I'm currently at 4.6.0.282, but i think there are even later versions now.
Fri Oct 09 2009 3:19am |
Matt_RRS_baby Member Since: 10 Oct 2009 Location: UK Posts: 1 |
got the same issue with mine so will give the upgrade a go.
Sat Oct 10 2009 8:53pm |
JonnyDangerous Member Since: 09 Nov 2009 Location: Reading Posts: 57 |
Hi all. First post on this forum after picking up my 2010 RRS. Everything great so far but have the same problem in that i have a blackberry curve which connects fine but the phone book doesn't show the names, only the numbers. Land Rovers web site does state that there are problems with the phone book. Has anyone managed to get the phone book to load correctly? |
Mon Nov 16 2009 6:16pm |
rrsowner Member Since: 23 Dec 2009 Location: Out In The Cold Posts: 34 |
Had the same problem with MY2010 SE and Blackberry 8900. After poking around a number of user forums it seemed that the problem was with the handset which was running on Orange modified software platform. RIM came up with a new version of the operating software (notified by running Blackberry Desktop software upgrade check) and once this was uploaded to handset (again using Blackberry Desktop software) phone book names and phone numbers transferred no problem. RIM software version is: v4.6.1.310 (platform 4.2.0.127). Hope this helps. Long suffering RRS Owner, but I can't help it! |
Wed Dec 23 2009 8:14pm |
Had the same problem. The BB OS upgrade solves the phone book name issue. Search my name on previous posts as i sent the link to the BB OS upgrade page.
Wed Dec 23 2009 11:37pm |
