Home > Maintenance & Modifications > Brake upgrade for s/c
ciaa
United Arab Emirates 2006 Range Rover Sport Supercharged Java Black
Apart from the horrifically expensive conversions from Overfinch or Arden, does anyone know if you can get an affordable disk and pad upgrade for the brembo's ??? Ive looked at EBC and Tarox but they dont seem to have the supercharged listed Confused
Im getting through pads and discs fairly quick.. maybe i need to drive a little more steadily Whistle
Thanx in advance 2006 RRS Supercharged
Hawke Saker 22" rims Nitto Tires
Larini exhaust System
ECU remap
Modified and ported supercharger with 3lb pulley
Post #238224 Sun Sep 27 2009 3:02pm
Supacat
Overfinch kit come from Brembo - Brembo Front Performance Brake Upgrade ( 6 Piston 15" 2pc Cross Drilled Rotors). Brembo Rear Performance Brake Upgrade (4 Piston 15" 2pc Cross Drilled Rotors) - so you could try them direct.
as does the Revere kit:
There's a company called paramount that do these:
and RPI Engineering does this kit:
AP direct would also do something to fit as might Wilwood:
You may be better going for some 2-part discs similar to these:
or if you really push the boat out some carbon discs:
[/img]
Post #238256 Sun Sep 27 2009 9:12pm
ciaa
Supacat.. thanks for the reply, they all look great but kinda pricey Confused .. I was actually after just a pad and disc upgrade using the standard calipers ..ill check out the paramount ones though, cheers Thumbs Up 2006 RRS Supercharged
ECU remap
Post #238377 Mon Sep 28 2009 6:50pm
Alias
Switzerland 2006 Range Rover Sport TDV6 HSE Java Black
F Sport is for the Lexus IS F?! Do they fit on a RRS? Confused
Post #238394 Tue Sep 29 2009 7:55am
Supacat
F Sports were used only as examples of 2 part and carbon discs...
Post #238497 Tue Sep 29 2009 9:54pm
Supacat
I think AP would be my 1st choice, they do a great range on their website and whilst I haven't checked, I'd be surprised if they didn't have any that were a straight swap.
Anyone know what the front and rear disc sizes are?
Post #238498 Tue Sep 29 2009 9:56pm
