Home > Technical > Starting problems TD8 |
Leo Member Since: 17 Sep 2007 Location: Nomad Posts: 554 |
Sounds like the ignition barrel - what you put the key into. Are there any fault codes? |
Thu Jun 11 2009 6:13pm |
will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377 |
Back to the dealer and unleash hell:
Thu Jun 11 2009 11:22pm |
mexi Member Since: 28 May 2009 Location: Rome Posts: 16 |
Good morning Leo,when I turn the key the system check is OK.
Fri Jun 12 2009 9:02am |
BigMart Member Since: 17 Mar 2007 Location: West Midlands Posts: 324 |
ISTR an issue with poor battery connections causing the same problem.
Fri Jun 12 2009 9:38am |
Hi Big Mart,LR told me that they check the battery....I hope .
Fri Jun 12 2009 9:50am |
I had this in my RRS - They needed to replace something, can't remember what but all I do know is that it's a to change. Warranty job. 2005 Zambezi TDV6 - Gone but not forgotten
Fri Jun 12 2009 9:56am |
It will be great if you can find the work papers or ask them what they did,so I can tell LR what to do !!
Fri Jun 12 2009 10:08am |
Jonathan Member Since: 11 Jan 2008 Location: York Posts: 434 |
Mexi
Fri Jun 12 2009 1:56pm |
Dear Jonathan,unfortunally that is not the problem.Even when the car is warm,after I wait for the system check etc...etc ,I have to turn the key 3/4 or 5 times before it starts.
Fri Jun 12 2009 2:06pm |
I just spoke to someone who had a similar problem - turned out it was the key itself.
Tue Jun 16 2009 12:12pm |
OK - so the thing to do is obviously change to your spare key and see if you get the same issue with that one
Tue Jun 16 2009 12:14pm |
Hi Leo,LR is working on the car right now,for the third time.I tried to switch the key....same problem.
Tue Jun 16 2009 12:20pm |
Riggers Member Since: 19 May 2010 Location: Salisbury Posts: 2 |
Hello,
Wed May 19 2010 7:35am |
Hi Riggers,they change the starter motor again...and I did not had any more problems.
Wed May 19 2010 9:26am |
