Home > Maintenance & Modifications > Faulty Bot Cover |
R22Flyer Member Since: 04 Feb 2007 Location: South Posts: 109 |
my cover in the boot has gone slack i have opened it up and wound the spring a bit tighter but each time its used the spring gets loose and after 2 uses its all floppy again, any else managed to fix it give me some ideas
Wed Apr 15 2009 10:06pm |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1936 |
The thought of you opening your Bot is horrible. If you have a slack bot then you should stop putting things in there. If I were you, I would keep your bot covered to stop anything coming out....(yuk yuk)
Thu Apr 16 2009 10:02am |
If you are still in warranty get it replaced. 2005 Zambezi TDV6 - Gone but not forgotten
Thu Apr 16 2009 10:04am |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 |
you're lucky to get 2! |
Thu Apr 16 2009 10:12am |
Thu Apr 16 2009 10:15am |
