Home > General > I've got a new phone/radio problem...
rweintra
United States 2006 Range Rover Sport 4.4 V8 HSE Java Black
OK. So, before anybody starts accusing my phone, its not my phone that is the problem.
If I'm on a call and another one comes in, I can switch over with no problem. Once I switch back, the 2nd call doesn't drop. Then I hang up the intial call and the 2nd call switch to the 1st line. It keeps blinking "1" until after I shut the car off for a few minutes. I can't get it to stop. It doesn't matter what button I press. Is there a way to force a call to end besides the paddle and the telephone button? I don't know what to do and just had to make a 45 minute drive on a highway without a radio because it was engaged with a non-existent call.
The phone itself is idle when this is happening. If I try to use voice dial, it goes through the whole procedure and then says dialling on the face, but doesn't dial. If I try to use the voice activation to change a radio station, it confirms the change but I can't hear it or see it. Any thoughts?
Post #11868 Tue Jan 31 2006 11:12pm
USAGivGrn
United States 2006 Range Rover Sport 4.4 V8 HSE Giverney Green
I had a similar experience. I believe I turned off my phone from the handset, waited a minute or two and reconnected. The multiple line feature is not supposed to be operable without using the cradle.
It certainly isn't ideal. I just wish people wouldn't call me so much.
Post #11872 Wed Feb 01 2006 1:01am
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
Call waiting is not supported through Bluetooth, only through cradled phones (I understand it may be a bandwidth limitation.) My phone behaves similarly to yours, if I pick up a second incoming call the system hangs indefinitely. So, I don't answer incoming calls anymore when I am already on the phone and let the second call go to voice mail instead. If you do/must answer that second incoming call and the system does freeze after you hang up, you can usually get the system back by disconnecting and re-pairing the Bluetooth link through the handset. However, each phone behaves differently and Call Waiting causes trouble 9 out of 10 times, regardless of what type of Bluetooth phone you are using.
Post #11879 Wed Feb 01 2006 5:35am
rweintra
Well, I have a cradle too, and just tried it with the cradle; doesn't work either. I tried hitting the menu button and going to "swap calls", but that didn't work. I hit the green paddle, that didn't work either. I don't know what to do now. I guess just let the second call go to voicemail. How annoying!
Post #12275 Sun Feb 05 2006 6:56pm
tony
Spain
same problem
I have the same problem exept sometimes my bluetooth will not connect
for days I put it down to the morons who fitted it mybe it is a common fault Crying or Very sad Crying or Very sad Crying or Very sad
Post #12678 Thu Feb 09 2006 4:52pm
rweintra
Just took a 6 hour drive in the RRS, and there is a new phone problem I am having. When the phone is in the cradle and someone hangs up, the "hang-up" paddle won't hang up the call. I have to take the phone out of the cradle and then snap it back in. How annoying!
Post #12723 Thu Feb 09 2006 10:33pm
