Home > Maintenance & Modifications > Suspension Lowering |
What else is possible? Or are the options limited only by ones imagination? 2005 Zambezi TDV6 - Gone but not forgotten
Fri Jan 27 2006 6:13pm |
LRtuning Member Since: 26 Jul 2005 Location: London and Melbourne Posts: 403 |
Well we could be wicked and have the rear windows open when you lock the car Chips with everything |
Fri Jan 27 2006 6:15pm |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 |
I noticed Arden are offering something similar. Separate box to allow one to select between an off-road and on-road program. On-road lowers it by 23mm and off-road lifts it by 26mm at a cost of 2300 euros.
Fri Jan 27 2006 6:55pm |
Josh,
Fri Jan 27 2006 7:03pm |
Slimer Member Since: 26 May 2005 Location: Nanny State Posts: 224 |
75mm? Is that a typo?
Fri Jan 27 2006 7:19pm |
TC,
Fri Jan 27 2006 7:21pm |
grommet Member Since: 28 May 2005 Location: Northern California Posts: 299 |
Yes, 75mm lower would be less than Access Mode. I don't think that would be safe to drive on. |
Fri Jan 27 2006 7:56pm |
What height does the suspension drop to at 100 mph +? TDV6 - gone
Fri Jan 27 2006 7:59pm |
20mm from normal on-road height. |
Fri Jan 27 2006 8:27pm |
Thanks for the info Grommet.
Fri Jan 27 2006 8:49pm |
rrmad Member Since: 29 Oct 2005 Location: UK Posts: 44 |
its easy enough to drop it by 150mm but that would be twice as stupid as 75mm. Little benefit to touching it unless you are going to make further mods, spent days road testing suspension heights. These autologic boxes can get the uninitiated into trouble - I'd stick with the chipping TC. |
Sat Jan 28 2006 1:01am |
noddy and bigears Member Since: 05 Nov 2005 Location: hants Posts: 116 |
can you fill us in more on your findings ie why a lower centre of gravity etc is of no benifit why is 75mm stupid etc some of us may like to know or is it just personal choice it could be an interesting thread thanks graham |
Sat Jan 28 2006 2:59am |
I assume rrmad is questioning why anyone would rethink Land Rover's engineering, especially if it's significantly different. I would, too. They don't design vehicles in a vacuum -- serious "real world" testing of the vehicle's handling and stability is performed. (Far more than any weekend "engineer" would do...) |
Sat Jan 28 2006 5:15am |
djsaad1 Member Since: 10 Aug 2005 Location: Texas Posts: 254 |
I dont understand why the car lowers at 100. What happens at 100 that the car needs to be lower? How many times are you really cruising at 100 for long periods of time. |
Sat Jan 28 2006 5:20am |
