Home > General > ROAD ANGEL PLUS SPEED CAMERA PROBLEM - NOT RECEIVING - WHY? |
Lookers Park Royal Member Since: 15 Nov 2007 Location: London Posts: 2303 |
I've had pretty much every Road Angel made, and found that the earlier models were very slow to find a proper GPS signal, however I currently have a RA Professional Connected which seems to lock-on within a maximum of 30 sec's or so.
Sat Nov 22 2008 11:10am |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 |
My old satnav doesn't work with my heated screen in a FL2, but connected perfectly if i stuck it on the sunroof, obviously not ideal place, but it was in a courtesy car i had on loan without OEM satnav
Are they any good, i was looking at one of those a little while ago |
Sat Nov 22 2008 1:38pm |
Npinks, in my personal opinion they are very good indeed, however perhaps a little expensive at the moment. It's quite a nice size, is rechargable (probably lasts 5 or 6 hours or so driving on a charge) but also has the facility of a cigar lighter charger. It powers down when stationary so doesn't run the battery down when at petrol stations etc, and with the 'connected' version you don't need to link it to the PC for updates (as long as you have GPRS signal). Overall I'm pleased with it. |
Sat Nov 22 2008 2:48pm |
Mintleaf Member Since: 18 Aug 2008 Location: London Posts: 77 |
I fitted an Origin B2 in my car, i had to install the antenna by the rear view mirror because of the heated screen... RR Sport TDV6 HSE 07MY Java Black |
Sat Nov 22 2008 11:04pm |
lemm Member Since: 03 Jan 2008 Location: London Posts: 135 |
i also have a Road Angel Professional Connected... works ok on right hand side of screen near dash RRS First Edition S/C, Vesuvius Orange, Rear Entertainment, Alpine TUE-T200DV, Stormer Alloys. (+ 19" MTR's for playing in the snow!) |
Mon Nov 24 2008 12:12pm |
RAD Member Since: 23 Sep 2005 Location: In the chippy! Posts: 309 |
The Pogo Alert with built in antenna works well sitting on the right side of the dashboard and sat signals are usually showing maximum.
Tue Nov 25 2008 2:53pm |
Jonny Fresh Member Since: 04 Feb 2008 Location: Manchester Posts: 3586 |
Are these speed camera detectors now worth having? The last time I had one (circa 3 years ago) they were , even the best ones. They had so many false alarms I actually threw mine out of the window in a fit of rage (until my girlfriend made me go back and get it )
Tue Nov 25 2008 3:11pm |
SILVER DOLLAR Member Since: 04 Nov 2008 Location: UK Posts: 44 |
Has anyone on this forum got a "ROAD ANGEL PLUS" that works in their RRS HSE? GUITARS AND CARS - YOU'RE EITHER IN OR YOU'RE OUT! |
Tue Nov 25 2008 11:56pm |
will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377 |
Goodbye L322 Big Daddy SUPERCHARGED 5.0 Autobiography - Here & Now! 5 series for the miles RRS S/C factory built HST - Gone 45 others have been and gone! |
Wed Nov 26 2008 1:10am |
Yes mine did, and it was right in the centre of the screen at the front. James |
Wed Nov 26 2008 8:32am |
That's really wierd then cos all I've done is move it from my 300c to this car. Worked perfectly before. James did your one have a sun roof? Mine hasnt. It MUST be the heated front screen! GUITARS AND CARS - YOU'RE EITHER IN OR YOU'RE OUT! |
Wed Nov 26 2008 9:37am |
No mine was in an HSE with a heated screen. It's also been in Disco's, FFRR's, FL2's and a Defender and was only a pain in the Defender because of the pitch of the screen being almost vertical.
Wed Nov 26 2008 9:44am |
I did a recent sync and reset. Can't understand this!!!! GUITARS AND CARS - YOU'RE EITHER IN OR YOU'RE OUT! |
Wed Nov 26 2008 9:48am |
Personally I'd plug it into the RRS on a clear day whilst stationary and give it a good 20 mins to lock-on, if it doesn't then I'd say you have a problem with the unit which has highlighted itself by moving between the 300C and the RRS.
Wed Nov 26 2008 10:39am |
