Home > Tips & Tricks > Bluetooth connection
cadee
Wales
Hi
Can anyone give me any tips. I have a Nokia 6500 slide phone which I have successfully paired to my RRS. The problem I have is that after leaving the vehicle, it won't re-connect automatically when i re-enter. I have to go through the phone menu and enter 2121 every time. My phone still shows 'LANDROVER' in the 'my devices menu on my phone, but as I say, it won't connect automatically. I don't think that there is a problem with the phone as it connects automatically to my work's van.
I have read the naviagation & telephone systems manual and noticed that a maximum of 8 phones can be paired to the vehicle. Is there a way of finding out how many phones are paired tot he vehicle? If so, can I delete some of the pairings (prehaps made by a previous owner)
Any tips would be gratefully received.
Post #190967 Mon Oct 06 2008 10:22am
Sexy Pauly
check your settings,
you may have to set up auto connect to devices from your phone, sometimes its nothin wrong, just the settings with your nokia!
it will be fine. RR Sport supercharged 06
strut grills, strut 22" wheels, Full Kahn Kit
Brembo big brake kit, tinted front and rear lights
CLS 63 AMG Mercedes 2008, Cayenne Turbo S 2007, C32 AMG mercedes 2004, Vito Van 111CDI 2004
Post #190972 Mon Oct 06 2008 11:12am
cadee
Wales
Thanks for your reply. I have checked my phone and auto connect is switched on. Do you have any other suggestions?
This is so frustrating because once the phone is manually connected it functions fine via bluetooth.
Post #190975 Mon Oct 06 2008 11:19am
bt11
I was having the same problem but this is how i solved it..
If you go to the Bluetooth setting on your phone, find your Land Rover connection, then options.. You need to make sure the connection is set to "autherised connection"
This basically allows your phone to connect when the Land Rover Bluetooth is found and connects auto without you having to key in the code Thumbs Upa Range Rover Sport TDV8 OVERFINCH ECU remap/tuned, 22" Satin Black Tigers, Black/Black, sideskirts, tints, clear ind, 09 upgrades +++
Plus others......
Post #191035 Mon Oct 06 2008 3:40pm
hario69
I have the same problem with my Nokia N97 mini - the Nokia N95 worked fine but N97 mini doesnt
Tried the settings on Nokia to no avail! Help!
Post #245597 Tue Dec 15 2009 9:48pm
Might not be a compatible phone. 2005 Zambezi TDV6 - Gone but not forgotten
Post #245598 Tue Dec 15 2009 10:04pm
