![]() | Home > Technical > BRAKE WEAR SENSORS |
| R33 Joined: 14 Jun 2008 Location: Marlow Posts: 50
Change the brake pads! |
| P44RY C Joined: 30 Jun 2008 Location: Cheshire Posts: 3
| Very Annoyed Site Moderator Joined: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 14917
Option 2 is to take the wheels off and gut the wire to the sensors. Option 1 is however your best bet!
| umbertob Joined: 23 Sep 2005 Location: Pasadena, CA Posts: 727
Just use the electronic parking brake to stop! Just kidding. The sensors are probably designed to be annoying on "purpose" - when activated it means your pads are worn down to almost nothing - less than 5% left I think - and you need new ones, pronto. But I also had to put up with that damn chime every time I touched the brakes not long ago in L.A. stop-and-go traffic, so I know what you mean. |
| MAW Joined: 06 May 2006 Location: Lincs Posts: 800
From memory ( i have just done mine) once on the edge of wearing and when the sensor is worn (shorts) the intermittent ding stops as the warning is permanent...
Involves brake pad change some time....
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: My arse, Your face. Posts: 20331
Yeah, much safer and easier on your ears and mental state if you just go and get them done |
