Forum Gallery Shop Sponsors Directory
Home > Maintenance & Modifications > Not sure if this has been discussed before, is there a way..
FAT_RRS
United States 2006 Range Rover Sport 4.4 V8 HSE Java Black
I want to disable the ride hieght control speed sensor. Sometimes, I'd like to ride around at off-road height, but if the car goes over 25mph, it lowers. Same with access height. I can see why they are limited for saftey reasons, has anyone found a way to disable the sensors? I really like to be up high sometimes on the highway.
Please let me know!
Post #174557 Thu Jun 26 2008 8:14pm
View user's profile Send private message Reply with quote
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
No solution. RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
On Order - LRX expected 2010
Post #174558 Thu Jun 26 2008 8:20pm
FAT_RRS
oh, man!!!
Post #174559 Thu Jun 26 2008 8:23pm
Texstar
Even if you did find a way of doing this, not only would the vehicle be less stable, the drive shafts / cv joints etc. would all be at more severe angles, and driving fast like this would probably knacker them all in next to no time. Just don't do it, FAT_RRS...$$$$$$$$$$$$$$$$$ Laughing RRS TDV8 Java (in my dreams). ..........Disco3 TDclankety clankV6 ............BMW 318i
Post #174562 Thu Jun 26 2008 9:43pm
EX-X5!
If you affix a large enough object under the relevant sensor underneath, the vehicle will think its 'bottoming' out and actually go even higher than off road mode. A large barrell lashed in place with rope might do the trick. Could work?
Post #174599 Fri Jun 27 2008 8:18am
check out disco3, the Australians where looking at the opposite Higher ride height due to those bumpy roads they need to drive down
Post #174601 Fri Jun 27 2008 8:36am
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
also check Matzkar in Germany they do a module that can raise or lower the car.
http://www.matzker.de/product_info.php?products_id=739 Sons of dogs come eat flesh
Clan Cameron
Post #174607 Fri Jun 27 2008 10:11am
Germany 2006 Range Rover Sport TDV6 HSE Java Black
Matzker is the way to go Cool 2006 RRS TDV6HSE java black/alpaca, Privacy, S/C Grille & Vents, debagded and rebagded, Stormers, Tasmod`s sills, RRSPORT umbrella and stickers
2008 Aston Martin V8 Vantage Roadster
PS: All my spelling errorz are copyrighted!!
Clicky!
Post #174660 Fri Jun 27 2008 1:12pm
Cyprus 2006 Range Rover Sport TDV6 HSE Java Black
Angel, I thought all things made in Germany were crap... Whistle
Or is that just cars? Wink 06 RRS TDV6 HSE, Java/Ebony, PTI, Running Boards, Privacy, S/C Grille/Vents, Stormers, Tasmods, Black Badge Soon...
PLEASE HELP DEVELOP TROTTERLAND, JUST CLICK A DIFFERENT LINK EACH DAY:
Population
http://trotterland.myminicity.com
Roads
http://trotterland.myminicity.com/tra
Industry
http://trotterland.myminicity.com/ind
Post #174661 Fri Jun 27 2008 1:13pm
Laughing Thumbs Up
Post #174671 Fri Jun 27 2008 1:59pm
mazhall
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
have a look at chelsea harbour motor compony thay have softwhere for this
Post #175027 Tue Jul 01 2008 2:30pm
John @ DW
Site Sponsor
We sell H&R lowering modules at Designer Wheels. Unlike fooling the suspension into staying at access height which is not deisgned for use at speed, the H&R module changes the dynamics also so it rides well and handles better. These are easy to fit at home, costs £1240 inc VAT & delivery (£1375 RRP) and lowers by 30mm.
We also sell Vemiri lowering modules that lower 40mm front and 30mm rear and these cost £1539 inc VAT & delivery (RRP £1714).
Post #175259 Thu Jul 03 2008 5:12pm
View user's profile Send private message Send e-mail Reply with quote
Pelyma
I think they want to raise the car not lower it. Like Npinks said look on D3 the Aussies cut one of the suspension rods which makes the normal height off road height (if that makes sense) DS3 TDV6 HSE
Silver with Alpacca
Post #175270 Thu Jul 03 2008 8:27pm
John @ DW
Site Sponsor
I believe you can raise the height of the off road setting using Autologic, in fact I think you can alter the height of any of the settings. If I remember rightly you can get upto an extra 25mm of height on the off road setting. Give to your local Autologic dealer a bell and I think they should be able to sort you out (so to speak!).
Post #175277 Thu Jul 03 2008 9:05pm
Leo
South Africa
The problem is not with off-road height, it's the fact that the car lowers itself at about 40mph that causes us problems. However, if we could raise the normal setting via Autologic, that could be useful.
Post #175290 Thu Jul 03 2008 10:19pm
Powered by phpBB © 2001 phpBB Group. SEO by phpBB SEO
Copyright © 2005-2008 Martin Lewis
