Home > Maintenance & Modifications > Nav on the Move (again, sorry) |
Given the software upgrade consists of inserting a new DVD, I'd say they were taking the pi**.
Thu Jun 26 2008 11:13am |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1667 |
That's what I thought, thanks.
Thu Jun 26 2008 11:38am |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1289 |
Just buy an updated NAV disc. The £95 might be to stick a new NAV disc in, let it upgrade (and that is automatic), then put your disc back in.
Thu Jun 26 2008 12:32pm |
I bought and use the latest Nav disk, but that reflashes the firmware which disables the hack so Nav on the Move is not possible unless you upgrade the software. |
Thu Jun 26 2008 12:46pm |
Hmm, that is not my understanding of it at all....
Thu Jun 26 2008 12:55pm |
I believe Navigation on the Move enables all functionality. There has always been limited functionality (such as the destination/home button, search condition, re-route) and the old hack code, which no-longer works following the latest Nav disk install, enabled all (such as postcode entry and retuning the blasted TMC ).
Thu Jun 26 2008 5:04pm |
FFRR is a different system though. NAV on the move hack then enabled more than just the new firmware Nav on the move. - I hope your £100 is not wasted. 2022 P440e AB |
Thu Jun 26 2008 5:25pm |
Thanks for all your help.
Mine's an 06 car and don't think it's on 07 model. Most of the Sat Nav functions greyed-out on moving - only the Destination/Home button, route search condition, and re-route functions were enabled. The 1791 coded worked to enable all functions whilst on the move. This year I upgraded the sat nav DVD, which I assume upgraded some firmware, and this has of course disabled the 1791 hack. The functionality is identical to previously - most functions grey-out on moving. I had assumed that "Nav on the move" allows one to 'enter new routes/postcodes etc whilst the car is moving', and other posts have talked about the only way to upgrade the software is through the dealer's diagnostic system which takes over 1 hour to download (some posts talk about 3 hours - indeed that's where my dealer got the ridiculous 370 quid from as they were charging for 3 man hours ). This is more than the DVD swap, surely. And how is the FFRR sat nav system different? Looks pretty damn similar to me. |
Thu Jun 26 2008 7:04pm |
Where the hell is Schmoogle when you need him? - Not sure about the FFRR system. I just thought it was a different one to ours. Hmmmmm. Looks the same you say? 2022 P440e AB |
Thu Jun 26 2008 7:48pm |
From Disco:
Assuming this is what they'll do, does line 15 mean they'll update the Bluetooth software too? Hope so. |
Thu Jun 26 2008 10:42pm |
Interesting. I had always thought that the nav on the go upgrade for pre-07 cars included both a firmware and software upgrade (in the form of an updated DVD and the TSB above) - but I remember having a conversation on here some months ago where I was convinced otherwise.... so now I'm confused. The TSB clearly does what it says on the tin, but is there a reliance on a new DVD also being required to support the new version of the firmware?
Fri Jun 27 2008 12:11pm |
You need the new DVD as well as the software update. 2005 Zambezi TDV6 - Gone but not forgotten
Fri Jun 27 2008 12:14pm |
We'll see in about an hour or so. The original garage phoned me back saying they would bite-the-bullet and do the software upgrade as per the TSB for the £95 quoted elsewhere "out of interest because they haven't done one before".
Fri Jun 27 2008 3:19pm |
...or they've melted your RRS
Fri Jun 27 2008 3:32pm |
