![]() | Home > Technical > Squeaky front end |
| bermyandy Joined: 09 Sep 2007 Location: London Posts: 186
Yeah, i had that. From memory it was worn bushes or something similar, and all covered under warranty
| NIM Joined: 02 May 2008 Location: TORONTO Posts: 7
Hi it is the front swap bar bushings HELLO EVERYONE,I HAVE BEEN WITH LAND ROVER FOR THE LAST 15 YEARS AND HAVE A LOT OF EXPERIENCE WITH THIS BRAND, IF ANYONE NEED ME TO ANSWER A QUESTION OR 2 DO NOT HESITATE TO
| will_wonka Joined: 03 Mar 2007 Location: Pouring hot oil on the local peasants Posts: 818
I too have had the dreaded squeak....turned out to be anti roll bar bushes and a loose |
| Nutty Nige Joined: 21 Feb 2007 Location: Staffordshire Posts: 330
I had the same on my old 07 model. Had some anti-roll-bar bushes made special with an internal diameter 0.004" smaller than standard- (tighter fit) I had them made with slots in the centre of the bush and filled them with vaseline to lubricate the anti-roll-bar as it moved sideways. Instant cure. It was a system I designed in 1983 on the early XR3i with the same problem.
| dukemasterpro Joined: 06 Jan 2008 Location: Sydney Posts: 26
Finally booked in for a checkup of the squeaking which turned out to be worn front bushes, fixed under warranty!
| Supertrotter Joined: 10 Mar 2006 Location: Freezing my spuds off in Blighty (For a few weeks anyway!) Posts: 7198
Glad it's sorted now |
Trivett Classic In Sydney - must say the whole process was good from drop off at the valet style service department, straight on a shuttle bus back into the CBD and a quick wash and vac at the same time for collection. They were not the supplying dealer either as I had bought from a Melbourne dealer through a fleet buyer. |
