Forum Gallery Shop Sponsors Directory
Home > General > indications on dashboard disappeared!!!
Reply to topic  Down to end
georgio
Cyprus 2008 Range Rover Sport TDV8 HSE Java Black
This morning i had my RRS TDV8 parked in an open parking under 36C. I dont know if the v.high temperature and/or the direct sunlight are the cause of the problem. When i switched on the engine everything appeared working normally until after 10-15 secs when all indications on the dashboard disappeared (The engine revs were zero, speed was zero, no fuel, no indications on the 2 screens on the dashboard, no lights, no indicators….. Nothing….. It appeared that the engine was switched off, although the car was operating with no problem.) Note that except the above problem the car was operating normally. After 30 min. i tried again and everything seems to be perfect.
I ve read another post from -panos- back in dec2007, he had excactly the same problem but no reply what happened next...
Sorry for my 'greek-lish' i hope you can undestand what is the problem, i ll appriciate any info/advise...
Thanks
_________________
RRS TDV8 HSE Java Black
Post #170442 Thu May 22 2008 12:56pm
View user's profile Send private message Reply with quote
You might find it was literally just one of those things... if it happens again, then it could be something faulty which your dealer will probably need to sort. But unless it happens again, I wouldn't worry too much.
_________________
Post #170444 Thu May 22 2008 1:01pm
MAW
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
S has it nailed with that diagnosis Rolling with laughter he used to work for LR you know Laughing Laughing
Sorry S ..... Rolling with laughter Rolling with laughter
Post #170476 Thu May 22 2008 6:16pm
georgio
Your advise pls...anybody???
I would appreciate if you provide me with some technical advice. Has this problem appeared to other cars also?
_________________
Post #170481 Thu May 22 2008 8:46pm
rrsjo
Re: Your advise pls...anybody???
This is not a regular problem and is likely to be caused by a poor connection somewhere - probably in the plug from the instrument binnicle. The heat may have been a factor. If it does it again get your dealer to check it out. Just one of those things I'm afraid and could happen on any car.
_________________
2008 TDV8, Stornoway Grey, ebony, zabrano trim, TV, Tasmods, mudflaps.
Post #170482 Thu May 22 2008 9:03pm
View user's profile Send private message Send e-mail Reply with quote
MAW
My view is that S can provide the comedy and the stealer is your best bet for the tech side...
A new car should be bug free in any saleable climate - LR are your target....
Post #170486 Thu May 22 2008 9:30pm
Reply to topic  Back to top
Powered by phpBB © 2001 phpBB Group. SEO by phpBB SEO
Site Copyright © 2005-2008 Martin Lewis
